help my truck is down an wont start up
Old Apr 3, 2012 | 07:18 PM
forhammer33's Avatar
forhammer33
had this isue last month runns fine one min wont start up the next changed the cam sensor fix the problem now its done it agine tried starting it with the keyles remote woundnt start done manuly it started it took it a second longer then normal later on that night it wouldnt start at all changed the cam sensor agine that didnt work this time are there any other sensors that keep it from running
Old Apr 3, 2012 | 07:40 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Check fuse #30 if blown unplug the fuel bowl heater and then replace the fuse. The fuel bowl heater plug is on the lower side of the fuel bowl on drivers side of fuel bowl.
Old Apr 3, 2012 | 08:21 PM
Pitcrw6's Avatar
Pitcrw6
Did you replace your CPS with a cheap parts store one or did you get it from Ford?
Old Apr 4, 2012 | 06:58 PM
forhammer33
to ancer every body fuse #30 was good i replaced the fuel heater last mounth and yes it was a cheap cps from auto zone but guess all is good in fordville once agine me and my son got to looking at the plugin an wiring the wiring looked and felt lose we wigeled it around and wala it fired right up should i get a cps from ford
Old Apr 4, 2012 | 08:03 PM
Pitcrw6's Avatar
Pitcrw6
Glad you found the problem.
Ol Country Boy
Jul 26, 2013 09:59 AM
Sparkplugless
37
Jan 12, 2012 03:51 PM
FoxNotch
22
Feb 27, 2010 06:21 PM
LUMBERMAN
17
Dec 23, 2007 05:10 PM
kyoung
Aug 23, 2006 01:26 AM
