How do I fix this rust?
Old Apr 3, 2012 | 01:14 PM
mr.fordneck's Avatar
mr.fordneck
Instead of describing it, I made a video,
How do I fix this rust? - YouTube
Thanks!
Old Apr 3, 2012 | 05:44 PM
Action4478's Avatar
Action4478
It needs to be sand blasted & then see whats left .. The door is real bad As well as the Rt side cab corner .. Use a 1/4 inch wide chisel on the drip rail to remove the seam sealer & blast it clean .. You will then see what you need to do .. I didn't see any body work , just plenty of rust ..
All of the spots you showed , you will not be able to get to the source of the rust , as it it due to multiple layers of steel , the rust begins between them , what you see is the result of that ...
Greywolf
Projects
Jul 10, 2012 12:32 PM
bamaf150
Jun 24, 2010 04:07 PM
sdeforest
1997 - 2003 F150
26
Sep 19, 2007 09:18 PM
Junker79
Paint & Bodywork
Jan 29, 2006 10:55 AM
Ford150/428/dud
Paint & Bodywork
Apr 21, 2005 02:00 PM
