Rust Stoppers
Old Apr 19, 2005 | 05:47 PM
Ford150/428/dud's Avatar
Ford150/428/dud
Rust Stoppers
What is the best rust inhibitor to use. Im looking for a rust inhibitor that you can apply right over the rust.
Old Apr 20, 2005 | 08:47 PM
Ford150/428/dud
Has any one used POR-15 on their trucks or heared of any one using it.
Old Apr 21, 2005 | 02:00 PM
1985 Quadravan's Avatar
1985 Quadravan
Yup. Sticks good to rough surfaces like rusted or blasted metal. Can peel off smooth metal especially if not prepped or aluminum. Use two coats to get a good hard finish. Make sure everything is bone dry before you start. Sponge brushes are economical, but tear apart on serious rust, so you might be better off with a cheap bristle brush. It can be sloppy and will permanently adhere to clothes. Not reccomended to spray. It's not a body filler so painted over rust will look like painted over rust. Gloss fades in sunlight to flat.
