6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
EGR cooler failure
Old Apr 2, 2012 | 08:10 AM
77scout's Avatar
77scout
EGR cooler failure
Hello,
I've got a 2010 F250, CC, 4x4, Cabela's edition with 34,xxx miles. I noticed last week that the engine coolant was low but could find no obvious leak. I took it in to the dealership and they called back saying that the vertical (diagonal) EGR cooler had failed and was leaking coolant into the exhaust stream.
I anticipate getting the truck back today........what other issues should I look out for? I can't imagine that burning coolant is that good for the turbos or the motor.
Thoughts?
Thanks,
Joe
Old Apr 2, 2012 | 09:44 AM
senix's Avatar
senix
Likely that would be in.
did you ever let the coolant get low enough to suck any air? If not then once filled you will want to watch it closely to ensure that the level remains constant and all air is purged out.
Old Apr 2, 2012 | 10:59 AM
77scout's Avatar
77scout
I suspect it did draw some air in as it was quite low. I check the fluids once a week and it went from normal to below the 'T' in one week.
I've read of some people having issues with cavitation when the level gets that low, but hopefully i didn't run it long enough to have any other issues.
Am I out of line to think that the dealership should change the oil after completing this repair? Knowing that the motor has been burning coolant, it would seem prudent (at least to me). I'm only 1000 miles from the next scheduled change, so if they don't do it I guess I'll go ahead and do it myself.
Thanks,
Joe
Old Apr 2, 2012 | 11:48 AM
senix's Avatar
senix
Thanks,
Joe
Seems wise to do so.
Old Apr 2, 2012 | 05:42 PM
parkland's Avatar
parkland
I wouldn't worry much at all about the coolant leaking in the exhaust a bit, at the rate it leaked it would have been a very small tinkle that would have evaporated rather quick.
troy676
Jul 6, 2015 01:25 PM
TexasBeachBum
May 12, 2013 09:07 PM
viper29
Apr 9, 2012 08:40 AM
bismic
Feb 15, 2011 10:12 PM
tracyclifton
Apr 30, 2010 09:02 PM
