What is it?
Old Apr 8, 2012 | 07:40 PM
viper29's Avatar
viper29
Exclamation What is it?
Noticed some white chalk like material on the water reservoir. Any ideas? Not running hot. Bad EGR cooler or head gasket going?
Old Apr 8, 2012 | 07:49 PM
1ton460bronco's Avatar
1ton460bronco
she "burped", was the coolant recently drained or filled? An air bubble can cause a slight burp if she wasnt fully bled. I have had 2 do that shortly after a coolant flush and refill
Old Apr 8, 2012 | 07:57 PM
viper29's Avatar
viper29
Yeah about 2 weeks ago, drained 2 gallons and replaced with antifreeze. coolant was very weak. I have new upgraded EGR cooler, oil cooler and some other things coming. I did not want to get it together and have to turn around and do the heads. thanks
Old Apr 8, 2012 | 08:06 PM
BLADE35's Avatar
BLADE35
I bet your Coolant Bottle was just to full
The new Full leval is the Low Mark
Mine rides about 1/2inch lower than the low mark all is good
Old Apr 8, 2012 | 08:12 PM
raptor131's Avatar
raptor131
Yep, I have been noticing the same thing. She is very particular on level! Too much she vomits!
Old Apr 8, 2012 | 09:13 PM
Roasted7's Avatar
Roasted7
I really hope you didn't put that green stuff in it.
Old Apr 8, 2012 | 11:04 PM
Snuggyworm's Avatar
Snuggyworm
no green stuff, no 50/50. only CAT ec-1 elc or zerex g-05 coolant or ford premium gold coolant. anything else and it compromises ur entire cooling system. be prepared for another "disaster". lol. kidding about the disaster, but u know wat i mean, stuff will break down. lol.
Old Apr 9, 2012 | 12:57 AM
berick's Avatar
berick
I'm scared to ask........ what happens if a fella DID use the green stuff?
Old Apr 9, 2012 | 01:47 AM
zhilton's Avatar
zhilton
The green coolant won't protect your engine against cavitation. It's not the end of the world...but you need to get it out of there (through flushes required) and refill with one of the three coolants Dom listed. Zerex G05 & Ford Gold are the same stuff by the way.
Old Apr 9, 2012 | 06:26 AM
bismic's Avatar
bismic
It is easy to spill a little coolant when you are adding it. No matter how careful I was. I would always get a few "chalky" spots.
1ton460bronco
I just had to re-do a flush by a not so local ford dealer who put the green stuff in after they did an egr and oil cooler! GRRRR
ud think they would know better
Old Apr 9, 2012 | 07:41 AM
Roasted7's Avatar
Roasted7
You don't want to mix the green stuff with the ford gold. You will have problems.
Old Apr 9, 2012 | 08:40 AM
69cj's Avatar
69cj
You also don't want to mix the Ford Gold/G05 with the Cat ELC either.
troy676
Jul 6, 2015 01:25 PM
SUPERTEK94
Aug 21, 2014 11:23 PM
TexasBeachBum
May 12, 2013 09:07 PM
Teds
Jan 18, 2012 06:22 AM
bismic
Feb 15, 2011 10:12 PM
