steering column
Old May 12, 2003 | 10:48 PM
79_ford_400_guy's Avatar
79_ford_400_guy
steering column
I think there is something wrong with my steering column.
I can move the wheel right and left about 1/4 in. both ways
Does anyone know what might be wrong with it ?
Old May 13, 2003 | 01:46 AM
baileybilt's Avatar
baileybilt
steering column
is it your column or the steering shaft in the column? if its the shaft in the column it could be a bad bearing.
Old May 13, 2003 | 06:02 AM
fordmaniac21's Avatar
fordmaniac21
steering column
try adjusting your steering box. a haynes or chiltons manual should tell you how to do it.
Old May 13, 2003 | 07:08 AM
macguyver's Avatar
macguyver
steering column
1/4" side to side without turning the wheel would be the upper bearing. 1/4" rotation would be considered excellent.
Old May 19, 2003 | 07:23 PM
MrTwister's Avatar
MrTwister
steering column
on my 77 F-150 you can turn the wheel alot with no tire movment. it is where the top saft connect to the string box. there is a little rubber dick that wares out.
Old May 20, 2003 | 02:52 PM
okiebronco's Avatar
okiebronco
steering column
is it 2x4 or 4x4? there is a difference in steering setup between the steering wheel and the gearbox is why i ask
