Modular V10 (6.8l)
PS hose help needed
Old Apr 1, 2012 | 08:05 PM
slammer's Avatar
slammer
PS hose help needed
I posted this in the other forum but thinks its more appropriate here. I need to switch out the high pressure line, its leaking at the pump. I can get the "top" fitting off but the one on the pump I cant get the wrench to go on.
the one on the steering box was 5/8" and came off nicely. I could even come close to getting the flarenut wrench on the other one.
Is there a trick? I can clearly see the fitting but cant get the wrench on it....thanks for any help cuz I am at wits end...tried for 2 hours to get it on there but to no avail....
thanks again
Old Apr 2, 2012 | 07:09 AM
TrdLtly's Avatar
TrdLtly
TreadLightly
One suggestion I just found was to cut the line as short as you can and then use a socket on it. It is already broken, so what would that hurt.
As suggested in your other thread, see if you can get a metric on it. On the new hose, compare ends. See what fits best.
https://www.ford-trucks.com/forums/1...lp-needed.html
Old Apr 2, 2012 | 01:15 PM
mudfuel06's Avatar
mudfuel06
I had an 02 that melted a hose after Ford's "fix" for it. I used crow feet wrenches to get it off, it took awhile.
Old Apr 4, 2012 | 08:32 AM
DarrellinCeres's Avatar
DarrellinCeres
When I replaced the viton seal on the end of the hose at the pump on mine I also had to use a crows foot on a 1/2" drive with a long extention to get it out of the way of everything to break it free. You should warm the seals in hot water to soften them to help get them on the hose fitting. It's a real tight fit.
lhud
Nov 20, 2014 10:34 PM
whitleycj
Jan 31, 2011 11:33 AM
78COBRAII
Feb 22, 2006 12:51 AM
aerovan
Aerostar
Aug 5, 2004 08:40 PM
boflaade
Dec 6, 2003 10:47 AM
