Sponsored by: Kumho
Power steer. pump return hose
Old Jan 7, 2006 | 11:34 AM
78COBRAII's Avatar
78COBRAII
My power steering pump return hose leaks like a horse with half a kidney! The original one is long gone so I replace with some high press. hose from ACE, but I cant seem to tighten it enough to stop it from leaking. Those stupid hose clamps just strip out! Please help! What do you guys use to replace the hose? Are the original ones still available? It is a 78 f150, 351M 4x4.
Old Jan 7, 2006 | 11:52 AM
ivanribic's Avatar
ivanribic
You can buy a replacement hose from Napa or most other parts stores BUT they'll charge more $$ than it's worth. If you are putting a rubber hose onto the portions of hard line in the system make sure they're flared at the ends (preferably double flared) to ensure a good seal so the hose can't slide off. Also, make sure you're using the right size hose. I'm not using stock Ford steering anymore but if I remember right it's a 5/16"ID hose that you'll want to sleeve that metal line properly. I may be wrong here, it's been quite a while so double check your measurements. Lastly, the grooves in hose clamps tend to bend when they're tightened (or overtightened) which will make them slip and strip out later. If you haven't already done it go to any hardware store and get some brand new clamps, make sure they're the right size and not too big. You should be able to tighten it up no problem.
Old Jan 7, 2006 | 11:23 PM
someday's Avatar
someday
car part stores sell them in bulk...most of the people that work at some of these places dont even know they have it in back
Old Feb 22, 2006 | 12:51 AM
RONEV's Avatar
RONEV
If you still havent found a fix, try two new clamps at each side of the joint. It worked on my pressure washer when the hose broke.
BCHauler
31
Jul 30, 2022 10:21 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Apr 26, 2013 11:39 AM
madpogue
16
Jan 31, 2007 08:29 AM
wjawill
1978 - 1996 Big Bronco
Nov 8, 2004 02:44 PM
