Flywheel Question help!!
Old Apr 1, 2012 | 01:28 PM
68cabby's Avatar
68cabby
Hi everybody..i need help!!! Im swapping a 300/6 into my 68 f100 from a 360. Its had a 4 speed t18. I was able to find the right sb bellhousing..but i was wondering if i could use the same flywheel?? I believe they both called for 11" but not sure. Im not changing trannys either.
Old Apr 1, 2012 | 01:44 PM
68cabby's Avatar
68cabby
Also..would i have to completely change my clutch?i.e. pressure plate..clutch disc..etc for a 300/6? Or would my clutch and disk work from my 360?
Old Apr 1, 2012 | 09:50 PM
Freightrain's Avatar
Freightrain
You'll need a 300 flywheel. FE and SBF are not the same thing.
As long as you get one that will accept your current 11" clutch, you can reuse that stuff.
Old Apr 1, 2012 | 10:12 PM
68cabby's Avatar
68cabby
Thats what i thought..hmm..now where to find a good used flywheel...is there specifics ond how many teeth it should have?
Old Apr 2, 2012 | 10:09 AM
Freightrain
Don't really know much about I6 motors. They made small versions back in the 60-70's, so don't use one of those(170/200/250ci).
Old Apr 3, 2012 | 12:13 AM
Austy's Avatar
Austy
New
You could always get a new one. LMC Truck Parts - Page 38
Old Apr 3, 2012 | 07:35 AM
68cabby's Avatar
68cabby
I have already looked to lmc haha all ot looked like they had were ring gears..im going to have to get a new one haha
Old Apr 3, 2012 | 01:53 PM
Austy's Avatar
Austy
I figured you had probably seen it, but I have known guys that have completely rebuilt these without ever having even heard of LMC.
Old Apr 3, 2012 | 06:22 PM
68cabby's Avatar
68cabby
Haha i appdeciate it. I figured theyd sell full flywheels..but theres nothin! Ive checked..ill have to end up goin tl ebay or summit
Old Apr 4, 2012 | 11:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C5TZ-6375-N .. 240 & 300 I-6 (Light Duty) Flywheel-164T Ring Gear / Obsolete
Marked: C7AE-6375-C / (6) 5/16" -18 pressure plate attaching holes on a 12 3/8" bolt circle / Use with 11" clutch.
Applications: 1965/72 Galaxie/LTD 240 I-6 / 1965/66 F100/250 2WD 240/300 I-6 / 1967/74 F100/350 240/300 I-6 / 1975/79 F100/350 300 I-6.
Econoline is not the same as above and the 300 flywheel is different after 1979.
ratrig
Jul 9, 2014 12:49 PM
satellites101
Sep 4, 2010 05:20 PM
outsource77
Jul 2, 2009 02:29 PM
hoxiii
Aug 28, 2006 06:09 AM
paulbunyan22041
Apr 9, 2004 07:03 AM
