Shifter cable removal
Old Apr 1, 2012 | 01:12 PM
jimbo285's Avatar
jimbo285
I can't tell without standing on my head under the dash, but how does the shifter cable disconnect from the column end? This is a 96 F250 with E4OD by the way. I don't want to just pull or pry it off and break something that i should have done first.
Old Apr 1, 2012 | 05:39 PM
peter_x's Avatar
peter_x
Three Torx-27 bolts if we're thinking of the same thing. They will be facing backwards as you are sitting in the seat, so you have to wrap around with an L-key (can't remember if a ratchet would fit back there).
Edit - I don't know if this makes a difference, but I had the column lowered a bit when I did this and I also had removed the other Torx bolts holding the shifter tube in, so maybe that helped a bit.
Old Apr 1, 2012 | 08:29 PM
jimbo285's Avatar
jimbo285
It was the cable i was trying to disconnect. I pryed it gently and it popped off like a throttle cable. Thanks though.
2008 F550
Jun 10, 2019 12:23 PM
Buckethead121690
Apr 28, 2018 07:55 PM
willowbilly3
Aerostar
Apr 19, 2015 05:51 AM
Expedang
Escape & Escape Hybrid
Nov 10, 2014 08:46 AM
imlowr2
Jan 1, 2006 09:04 PM
