distributor problem 351 windsor
Old Mar 31, 2012 | 11:41 PM
ian_ak's Avatar
ian_ak
ok i just got done putting in a 1973 351 windsor into my 1977 f150. my truck had a 300 i6 in it before. the distributor that i have now is not electronic. does any one know how i can wire it to not have the electronic ignition or what distributor i need to keep the electronic ignition.
Old Apr 1, 2012 | 12:01 PM
ian_ak's Avatar
ian_ak
any help would help. does any know if a distributor for a 76 with a 351 windsor would work.
Old Apr 1, 2012 | 12:03 PM
ian_ak's Avatar
ian_ak
would i also need a new ignition for a 351 or will the one from in 300 i6 work?
Old Apr 1, 2012 | 12:15 PM
HIO Silver's Avatar
HIO Silver
Why don't ya just install a Pertronix module? It's simple and dang near bulletproof.
Old Apr 1, 2012 | 02:13 PM
ian_ak's Avatar
ian_ak
if i were to install the pertronix module would it plug into my stock electronic ignition from my 300 i6?
Old Apr 1, 2012 | 02:22 PM
HIO Silver's Avatar
HIO Silver
The '77 300's distributor will not work in your 351W.
You'll need a Pertronix module for the 351W's non-electronic distributor.
Old Apr 1, 2012 | 02:58 PM
ian_ak's Avatar
ian_ak
i know the distributor will not work. i am wondering if a 76 or so 351 electronic distributor will work on my 73 engine? or how would i wire up the distributor with points to eliminate the electronic ignition.
Old Apr 2, 2012 | 09:59 AM
jsutton's Avatar
jsutton
Yes you could get a distributor for any 351W that uses the duraspark II. Since your truck is a 77 all the wiring for the duraspark II is already there and you just need a 351W duraspark II distributor.
First thing that comes to mind is a 78 LTD with a 351W. We did this when we changed my brother's 84 from the EEC IV over to the duraspark II ignition.
Old Apr 2, 2012 | 02:19 PM
Ken(Ark)'s Avatar
Ken(Ark)
Originally Posted by ian_ak
...... the distributor that i have now is not electronic. does any one know how i can wire it ......
If the distributor you have is a points style distributor then hooking it up is simple .
Distributors are basically a switch that tell the coil when to fire .
Most coils need a resistor to drop the voltage .
Power the positive side of the coil - through a hot wire from the ignition switch - through one of those ceramic resistors to the "+" side of the coil . Or buy a $15 14volt coil from the parts store that "does not need a resistor" .
The one wire that comes out of the point style distributor hooks up to the "-" negative side of the coil . When the points close it completes a circuit and tells the coil to fire .
Hooking up an electronic Ford distributor is not hard .
For about $50 including shipping you can buy a complete distributor that only needs a hot wire hooked up . It is an HEI chevy style conversion distributor with built in coil that fits the Ford 351w motor .
The clear cap is cool too .
A 351 Windsor distributor will not interchange with any other motor ( with out mods ) so you will have to get one specifically for the 351w .
FORD 351W WINDSOR HEI DISTRIBUTOR 6510-CL | eBay
ford300fan
17
Sep 28, 2017 09:41 PM
trumsey07
Dec 31, 2011 10:00 AM
smokee
Apr 30, 2006 11:47 AM
yellow tonka truck
May 17, 2004 02:15 PM
cant remember
Sep 24, 2003 10:29 PM
