Starter For 352
Old Mar 31, 2012 | 04:12 PM
birdhaus's Avatar
birdhaus
Cool Starter For 352
Anyone have a good source for a starter?, the whole shootin match.
As a side note... the damn thing tried to kill me today.
Apparently the solenoid Stuck, so as I installed the battery (with truck in gear)
It fired off, Pinned me against the shelving in my garage before I could yank the power.
Yes... stupid on me, can't blame the starter, but still, it must go...
Its been behaving sketchy, and gets a ton of heat off the headers.
Old Mar 31, 2012 | 04:49 PM
66f-100's Avatar
66f-100
Any parts house should have it or be able to get one. You will most likely have to remove the header to get the starter off. 2 out of 3 bolts on the starter are easy to get off. Use a long extension and a socket to get the remaining one off, it will make it much easier.
Old Mar 31, 2012 | 05:25 PM
birdhaus's Avatar
birdhaus
Right. I'll see if I can find a heat blanket while I shop.
Thnaks!!
Old Mar 31, 2012 | 06:06 PM
OldHarley's Avatar
OldHarley
Just so you know, they do make smaller starters that give more room for a heat blanket.
The standard size starter makes it a little tight to install a heat shield.
A lot of folks here swear the heat from the headers don't affect their starter, but I had trouble with mine and finally went back to stock cast iron manifolds.
Old Mar 31, 2012 | 06:29 PM
ul37's Avatar
ul37
Are you sure its the starter and not just a bad relay(solenoid)?
Old Mar 31, 2012 | 06:39 PM
cheddar89's Avatar
cheddar89
Christine's back lol
Old Mar 31, 2012 | 06:50 PM
birdhaus's Avatar
birdhaus
Blanket room
Good to know... Thanks.
Old Mar 31, 2012 | 06:52 PM
birdhaus's Avatar
birdhaus
Exactly!
I was considering retaliation, but that leads to another horror film.
Old Apr 1, 2012 | 09:43 PM
birdhaus's Avatar
birdhaus
Talking starter
You are most likely correct that its simply a bad solenoid, I'll probably start with that.
I have a tendency to over react when my truck tries to run me over.
Bad truck.. Stay.
Old Apr 2, 2012 | 11:50 AM
rustywheel68's Avatar
rustywheel68
yeah- sounds like the starter was doing its job...just a bad relay.
the new ones have a reputation for sticking open.
the heat blanket is a good idea if you're running headers. i used to run a mini-starter without any problems (or blanket), but like OldHarley said, your mileage may vary.
as you've seen, that little solenoid is an absolutely critical part...you may want to spend some money on a real one. the last one i got from Napa stuck open after just a year, even though it had set me back $20.
my next one will be a Cole-Hersee.
have you checked your neutral-safety switch? sounds like it needs adjusting.
glad to hear you didn't get seriously hurt.
Old Apr 2, 2012 | 07:12 PM
ul37's Avatar
ul37
I beleive you can still get one from Ford.
Old Apr 2, 2012 | 09:15 PM
birdhaus's Avatar
birdhaus
Solenoid on the way
Thanks!
I ordered a solenoid... on the way.
Do you guys experience parts store frustration as much as I do, they may as well call them Chevy Shops. Maybe it a regional phenomenon, but the 4 major
chain store locally don't seem to stock very many Ford parts.
They could fit a lot more parts in those stores if they did away with those crazy HID light displays everywhere >rant over<
chiefsfootball
20
Dec 16, 2015 10:35 AM
wasowski
15
Apr 10, 2013 09:17 PM
F-250 restorer
Jul 19, 2012 01:10 AM
HogTied
Aug 3, 2011 08:14 PM
themaker
Jan 9, 2005 01:12 PM
