remove steering wheel with hammer?
Old Mar 31, 2012 | 01:05 PM
78ford351m's Avatar
78ford351m
I was told this is possible but I have pounded and pounded on the center nut. Removed the main nut. What is the trick I am missing?
Old Mar 31, 2012 | 01:13 PM
J ballan's Avatar
J ballan
Use one knee on the bottom of the wheel and one hand on the top pulling towards yourself and give it a good smack with good size hammer. Make sure you keep the nut on a few threads so when it comes loose it doesn't hit you in the head.. On a second note I would recommend using a puller because it is safer and Will cause less damage to the steering column. Good luck.
Old Mar 31, 2012 | 01:26 PM
customrich&matt's Avatar
customrich&matt
makesure the nut is almost all the way on
so you dont bend the shaft if you dont
hit it flat
bin there done that
Old Mar 31, 2012 | 01:33 PM
jim collins's Avatar
jim collins
Wheel puller,a good one will last a long time. I hate it when i get a hold of something somebody has beat the crap out of. Got one once somebody had beat on it like you are. Then after getting it off they ran the nut on and cross threaded it ,then left it that way until i got it. Ruined the shaft. But good luck.
Old Mar 31, 2012 | 02:38 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
If you can't or do not really need to buy a puller, rent one at a local parts store?? The hammer trick is not the best route to take IMO.
Old Mar 31, 2012 | 02:45 PM
Caleb H's Avatar
Caleb H
A little steering wheel puller kit is right around $10 if that, and a lot of them include different bolts for one-size-fits-most. They're good to invest in! You never know if you'll have to pull that wheel off again to fix something else.
Old Mar 31, 2012 | 03:00 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Proper tool for the job. Buy it once and forget it. Kind of like a power steering pully remover, you save the price by not screwing stuff up. Everyone needs more tools.
Old Apr 1, 2012 | 12:01 AM
cowboywanabe's Avatar
cowboywanabe
Posting Legend
My local parts store (O'Reilly's) had a free loaner. They require a $35 deposit, but as long as you bring the puller back within 3 days, you get the deposit back.
Fiveflat
Apr 12, 2018 10:13 AM
Rasputin53
Apr 2, 2014 11:24 AM
Christopher2
Jul 28, 2012 11:01 AM
bishopgeer
Sep 11, 2009 08:05 AM
dude74crew
Mar 28, 2008 12:21 AM
