FPR shimming
Old Mar 31, 2012 | 11:55 AM
timmyboy76's Avatar
timmyboy76
FPR shimming
Not a fan, but its a temporary fix to see if it corrects my problem. Anyway, i got the info to performing the task but for cutting the bolt, is it 3/16in from top of bolt to bottom of threads or 3/16in thread length?
Old Mar 31, 2012 | 12:34 PM
woodnthings's Avatar
woodnthings
The threads fit in the spring. I have always seen just the head shaved down to create the "shim". 3/16" seems a little big. With the "BB" used it less than that. Figure a BB is .177" and a good portion of it sits in the spring. I would think maybe .120" is all that is being shimmed. with 3/16" (.1875") that is quite a bit more when using a socket head cap screw.
Old Mar 31, 2012 | 12:46 PM
timmyboy76's Avatar
timmyboy76
Hey Ken..i dug up a few threads..here, other forums..etc, and all point to the 4/40 hex head cut at 3/16in length. Maybet he B.B. is for the OBS??? Got off the phone with FORD, and this sux, cant buy just the spring...
Webshots Rides offers thousands of the best car wallpapers.
Old Mar 31, 2012 | 01:17 PM
fmtrvt's Avatar
fmtrvt
Ford SuperDuty - Modification; 7.3L Fuel Pressure Shims | Facebook
Old Mar 31, 2012 | 01:18 PM
woodnthings
No, there is more than one way to skin a cat. The BB can be used like the screw. It isn't "adjustable" like the screw as it is a little hard to shave them.
Either way you do it, the spring gets more tension. Why did you cut yours down?
Clay and Bob can get springs. I would call them up over Ford any day.
Old Mar 31, 2012 | 01:20 PM
timmyboy76's Avatar
timmyboy76
way better link..thanks. What you think about the last pic, taking psi reading from the drain tube? If accurate enough, then with my 1-coil clipped, i dont think i'll see much/if any psi boost....da$#
Old Mar 31, 2012 | 01:25 PM
timmyboy76's Avatar
timmyboy76
Ken, i clipped it because, after a year +/-, my pressure starting rising. Got to the point i was uncomfortable with it..80+. So, with the help of the FPR kit being 65 buks, i removed the plunger, wet-sanded the "hard spots", tried psi reading again, was better but not low enough. So, i figured, what the heck. i cut 1-coil and since then, the psi has been great..65/66psi, with little to no drop ay WOT, PLUS the injector noise (thats what i'm say'n it is) was depleted to almost nothing.
Now, i'm at 56/57psi, drops to 52 WOT, and not happy. Performance is great, but the starting of motor is whats bugging me...
Ken, after checking the pic, i think i'm going the B.B. route...thx
Old Mar 31, 2012 | 01:27 PM
woodnthings
I don't think I would waste my time on using the drain tube. There are two perfectly good ports on the fuel bowl to use. That is what I use and would use. Why monkey with using clamps and such when you can just pull a plug. You can use simply hardware store fittings to thread into it too.
Old Mar 31, 2012 | 01:38 PM
timmyboy76's Avatar
timmyboy76
Absolutely....i'm hit'n the hardware store inna bit. Gonna get a few B.B.'s, hopefully in different sizes, and will take note and post back. Then again, thinking about it, i believe #'s will be different for each member, depending on condition of FPR, fuel pump..etc. Either way, i post up my findings.
Old Mar 31, 2012 | 04:17 PM
timmyboy76's Avatar
timmyboy76
.....After spending over an hour looking for the elusive 4-40 sockethead, i gave up. Came home thinking i could hit a neighbor up for a BB, with no dice there too. So, looking around and just happen to look at my air compressor, and thought, HEY, theres bearings in the couplings. So, went to toolbox where my pneumatics are and broke one open. Removed the FPR, installed bearing with spring(dont forget, my spring is cut by 1-coil), buttoned everything up, turned key on, let g.p.;s cycle, and BAM..fired right off, with a standing 72/73psi...WOOHOO. You guys think thats an acceptable psi or a tad on high side?
BlackNGoldRules
1983 - 2012 Ranger & B-Series
Jul 26, 2010 03:57 PM
Talyn
17
Sep 1, 2009 12:14 PM
Fuggrur
May 23, 2005 06:11 PM
Super Steve
Dec 3, 2003 07:23 AM
51dueller
17
May 26, 2003 11:53 AM
