UH OH ELECTRICAL ISSUE!
Old Mar 31, 2012 | 12:41 PM
SpringerPop's Avatar
SpringerPop
Originally Posted by 94WhiteF250
Does anybody put anything on the terminals to prevent it from happening?
I used to use a light coating of RTV on the horizontal surfaces around the terminal. Now I just use wheel bearing grease.
The seal between the terminal and the case is imperfect, and allows a small amount of the acid to migrate up onto the terminal, causing corrosion of the copper cable termination and the steel bolt and nut. The lead is mostly unaffected by the acid, but will oxidize in the air.
Most anything non-conductive and acid-resistant that will augment that seal will work just fine. Just use it sparingly and keep it off the surfaces that mate.
Those colored felt pads don't work all-that-well on their own, but will be fine if used with grease or RTV.
Pop
Old Mar 31, 2012 | 07:18 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
I still just don't know if that is 100 percent.
May not be, but when a battery is these vehicles gets strangled from the alternator due to corrosion, and this has been going on long enough to create no start, that battery is only going to let you down sooner than later. The other battery has been working twice as hard, and the alternator is not liking the extra resistance within the charging circuit. Get it load tested and keep an eye on it. Otherwise it will bring other things down with it, and fail at the worst possible time.
Good Luck!
Old Mar 31, 2012 | 08:44 PM
SpringerPop
What the heck does this mean?
Those are terms that don't normally apply to charging and storage systems.
'Splain us, please.....
Pop
Old Mar 31, 2012 | 10:58 PM
Whitey Ford
"when a battery is these vehicles gets strangled from the alternator due to corrosion,"
A single electrical storage device (SESD), in a dual electrical storage system (DESS), will become compromised when said SESD is isolated from it's charging source, due to a high resistance connection.
When a SESD is found to be compromised, thorough testing by trained professionals, is recommended. Proper testing of the SESD may also prevent additional component failure within the DESS.
It is also recommended to test all other components of the DESS after being electrically and thermally stressed by an unbalanced DESS, caused by a compromised SESD.
Old Mar 31, 2012 | 11:47 PM
Pitcrw6's Avatar
Pitcrw6
Holy cow you went straight over my head with that. My hair is still on fire and head still spinning. Do I need a NASA degree to understand that!!!
Old Apr 1, 2012 | 01:15 AM
SpringerPop
In sixty-five years, I have never heard of these terms before.
Are these recent terms, now coming into common usage? They sound as though they are from a textbook.
Pop
Old Apr 1, 2012 | 02:03 AM
big poppa's Avatar
big poppa
Pop
If ligget, we could have Earnest Eugene's son or family member back with us, no disrepect, wished he was still around, hum.. No electrical guru here in any sense of the word but listening.
corpse
1997 - 2003 F150
Feb 6, 2009 03:30 PM
EKWBTX66
Apr 8, 2008 04:24 PM
tiredbeat
1997 - 2003 F150
Jul 20, 2007 01:52 PM
Jon Henry
Electrical Systems/Wiring
Apr 21, 2006 08:46 PM
Hungryhow18
Aug 19, 2004 07:32 PM
