Help! Truck won't start!
Old Mar 30, 2012 | 10:03 AM
diesel_girl04's Avatar
diesel_girl04
Two questions, first is there anyway to edit my user name. I have a "smart" phone that can't spell
Also, I have a 2004 Ford f250 super duty diesel pickup. A few weeks ago my radio started switching channels and the volume would increase. I turned it off for about 5 minutes and never had another problem. Today I went out and started the truck, rolled the Windows down to get the fog off, then went to feed while the truck warmed up. When I pulled out of the drive way, I realized the clock/radio, interior lights, and Windows were not working. I had gone about a 1/4 mile (still on my dirt road) so I stopped and turned off the truck (wanted to make sure I could start it, so I wouldn't be stranded). The truck is still down there
Does anyone have a clue what caused this. Other than the radio that one time I have never had any trouble at all with this truck. I though maybe a blown fuse or a bad battery. I did try to jump it but the only thing I had was my little john deer gator. I don't think its strong enough.
I did have the oil/filter changed last week, and I use Lucas fuel additive.
Last edited by diesel_girl04; Mar 30, 2012 at 10:16 AM. Reason: because its hard to type on a phone
Old Apr 2, 2012 | 07:16 PM
megawatt00's Avatar
megawatt00
Welcome to FTE I moved your thread to a more specific forum. These guys will help you out .
Old Apr 2, 2012 | 07:27 PM
GreenPSD's Avatar
GreenPSD
So much for "smart" phones. Does the motor even turn over? What is the age and conditon of the batteries?
Old Apr 2, 2012 | 07:42 PM
critterf1's Avatar
critterf1
Weak batteries will do some "weird" things.
Old Apr 2, 2012 | 09:06 PM
wulfman's Avatar
wulfman
I would check batts and also check what type of filter was put on your truck when oil was changed. Where did you take it you CAN NOT let just anybody do a oil change in a 6.0 .
Old Apr 2, 2012 | 10:36 PM
Snuggyworm's Avatar
Snuggyworm
i would change both batteries, and also do a voltage test on the FICM if u can crank.
Old Apr 3, 2012 | 10:13 PM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
Directions for how to test the FICM voltage are in the tech folder and also over on FICMrepair.com on the FAQ page. I'd also be curious to see what the voltage on the batteries were. As was stated, fried batteries can cause all sorts of issues!
Keep us posted!!
Old Apr 4, 2012 | 10:00 AM
zhilton's Avatar
zhilton
It wouldn't hurt to check and make sure both batteries have good clean post contacts. A bad ground will do all kinds of crazy things too.
Hugh Jasswal Rus
1978 - 1996 Big Bronco
Jul 21, 2015 01:05 AM
jhaines10
6.7L Power Stroke Diesel
May 10, 2015 02:10 PM
kmonty2
Jul 26, 2011 01:02 PM
brick594
2004 - 2008 F150
Aug 11, 2004 09:40 PM
ousch
1997 - 2003 F150
May 3, 2004 01:10 AM
