272 ecy engine code info
Old Mar 29, 2012 | 08:03 PM
papisox's Avatar
papisox
Hi,
I am taking apart my 1955 F100 and the engine has a tag on side with ecy code. I can't find much info and assume the engine was replaced at some point in the past. From what I can find it is a 272? Does anyone know what models this came in and best way to rebuild it to get good power?
Old Mar 29, 2012 | 08:28 PM
HT32BSX115's Avatar
HT32BSX115
Originally Posted by papisox
Hi,
Howdy,
Welcome aboard!
The best way to identify your engine is to look at the left side of the actual block for the block "code"
The following link will have all the possible codes.
TECHNICAL
I think the 55 trucks actually came with a 239 (OHV Y-block) V-8.
My 55 F-600 had a 239 that someone put in it several years back. I currently have a rebuild 60 model 292 for it now.
If it actually IS a 272, you can rebuild it and bore it out. Again the site above will indicate what you can do with it to include a little "stroking"
The 272 is a great engine! If it's a 239, there's not a lot you can do to "speed-tune" it. Most people put 239's in their 55's because they want to have a completely original engine in it. They're not a power-house" though.
Get yourself a Photobucket or other photo-hosting account that can host your pictures. Then you can post them here for everyone to see. We all LOVE pictures!
Cheers,
Rick
Old Mar 29, 2012 | 08:32 PM
papisox's Avatar
papisox
Originally Posted by HT32BSX115
Howdy,
Welcome aboard!
TECHNICAL
Get yourself a Photobucket or other photo-hosting account so you can hose pictures. Then you can post them here for everyone to see. We all LOVE pictures!
Cheers,
Rick
Thanks Rick,
I've checked that site but there is no ECY code on that page. Side of engine has ECY on it. Thanks
Old Mar 29, 2012 | 09:02 PM
HT32BSX115's Avatar
HT32BSX115
Thanks Rick,
When you say "Side of engine" are you talking about the actual cast-in letters? I thought you said it had a "tag" on it?
If it's an actual "tag" Then you'll need to look at the actual block. If the block has "ECY" on it, I don't know. It might not be a Ford Y-block at all then.
I think a lot of parts have ECY on them though. Manifolds, etc.....
Old Mar 29, 2012 | 09:34 PM
papisox's Avatar
papisox
There is a stamped tag on drivers side below head that says something like certified ford rebuilder and engine code says ECY.
Old Mar 29, 2012 | 11:08 PM
HT32BSX115's Avatar
HT32BSX115
The actual engine code is cast into the block.
<b><big>Block identification number generally on side of block above oil filter for blocks cast at Cleveland. Dearborn block I.D. number near distributor and above generator. Most Dearborn blocks used in trucks. No Dearborn blocks after 1957. There were no special truck blocks. Heavy duty trucks with steel cranks used C1AE or C2AE car blocks. Nearly all Dearborn blocks after 1954 were 272's. Most 292 and 312 blocks are from the Cleveland foundry.</big></b> www.ford-y-block.com
Anything hand stamped into the block by someone else is not a block identifier...
Old Mar 30, 2012 | 07:16 AM
raytasch's Avatar
raytasch
Believe Nothing
Try this link for Y block engine ID codes.
Identifying Ford Y-Block Parts (Part 2) Precision Engine
Old Mar 30, 2012 | 02:44 PM
HT32BSX115's Avatar
HT32BSX115
That's a good one.......... Although no better than Mummerts...
Neither one appears to indicate an "ECY" block......unless I just cannot see it.....
Either someone "stamped" it wrong or he's looking at something else.....(not a Y-block)
Old Mar 31, 2012 | 12:38 AM
papisox's Avatar
papisox
I read another post on here where someone said it was in the 55-56 manual coming from a F350 and bigger. Another post also showed 56 F600 as coming with 2 versions of the 272, one which was ecy code. Its definitely stamped ecy, not reading it wrong.
Links to posts:
https://www.ford-trucks.com/forums/54984-1956-f600.html
https://www.ford-trucks.com/forums/5...-not-help.html
https://www.ford-trucks.com/forums/5...gine-code.html
Old Mar 31, 2012 | 04:07 AM
Jeeeppy's Avatar
Jeeeppy
I too was having problems with identifying my y block but with help from doing several searches on this site I surmised it to be a 272 not a 239 as it was sold to me as.
Should be three letters then number I.e ( ECG) 60150 which are cast into block upside down below heads at opposite end to clutch flywheel end of engine.
Hope this helps did for me
Old Mar 31, 2012 | 11:42 AM
HT32BSX115's Avatar
HT32BSX115
Links to posts:
Yeah. I saw those too. That is maddening! The usual y-block lists seem to have omitted ECY. I wonder why?
If it's an HD version of 56 272, that might explain it but according to Mummert and other Y-guys, there was no difference between the blocks for cars & trucks.
I'll ask him. I am sure this question has been asked many times between 1956 and now!!
In any case, all the Y-rules apply. you can pretty much rebuild a 272 as a 292. If you want to know all the details, you might go over to http://www.y-blocksforever.com/forums/default.aspx
Those people have done everything to a Y-block that can be done, including MPI-EFI and (turbo and belt-driven) supercharging.
Regards,
Rick
49m47
Nov 20, 2023 11:19 PM
Y-Blockhead
Apr 14, 2014 08:50 AM
merten
Nov 22, 2007 09:22 PM
55and65effies
13
Jul 22, 2006 08:08 PM
HarleyChix86
Aug 16, 2002 12:27 AM
