Rebuild Date????Crack the Code
Old Nov 22, 2007 | 05:59 AM
merten's Avatar
merten
Hi All, and happy Thanksgiving.
My truck has a 239 flathead that I believe was rebuilt long ago. I am trying to figure out when? I read somewhere that Ford re-builders sometimes re-stamped the engine build date code found on the top machined surface of the block. I think that the Twin Cities re-builder of my engine did that because the stamped code doesn't make any sense. Here are some pictures. Maybe some of you Ford parts guys can help me with this.
Although it is hard to read in the second picture the stamping is clear,
it is C 2 W
The first picture shows a decal on the left cylinder head.
The last picture is a data plate riveted to the block near the coil.
<CENTER></CENTER>
Old Nov 22, 2007 | 08:20 AM
53OlderThanMe's Avatar
53OlderThanMe
If they followed the Ford codes the C2 would stand for 1962 but the W?
Old Nov 22, 2007 | 08:50 AM
merten's Avatar
merten
This link provides some info on the code, but my engines code for the year(last character) doesn' work because it is a W
http://flatheaddrag.com/birthday.html
Old Nov 22, 2007 | 09:07 AM
53OlderThanMe
Can't see the picture well with the stamping but is it possible the W is actually an H? Most of the time I misread these stampings.
Old Nov 22, 2007 | 09:57 AM
merten's Avatar
merten
Better Picture of Code
Old Nov 22, 2007 | 11:10 AM
4tl8ford's Avatar
4tl8ford
I got to believe that whoever stamped that messed up the "M" stamp.
Old Nov 22, 2007 | 02:12 PM
mtflat's Avatar
mtflat
Most info on rebuilt engines indicates the rebuilder, factory or aftermarket, ground the original date code off. I've never seen or heard of a rebuild with a assembly date still on the intake flat, but there's a first time for everything..........
I have a hunch only the rebuilder knows what C2W stood for.
Old Nov 22, 2007 | 03:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C could stand for March. 2 for the day: March 2nd.
In Ford production date codes, C is the third month. (Example: '65 Mustang production date: 02C = March 2nd, 1965)
The W could stand for the size of the parts (.030 etc) installed, or an assembly number. It could also be an employees code letter, the guy who did the work.
Old Nov 22, 2007 | 05:13 PM
John - NNY's Avatar
John - NNY
This is a picture of the number stamped on left side of block between intake manifold and left head. This is on a stock 337 ci. flathead. The first number is 'N1718'. It has been crossed out with the number one. The second number is 'P4051'. I don't know what they mean.
John
NNY
Old Nov 22, 2007 | 09:22 PM
merten's Avatar
merten
Thank You All for your replies.
Does anyone have any Idea when they stopped using the blue ribbon Ford re-builder stickers?
gus11208
22
Nov 5, 2010 04:43 PM
fxstbchopper
35
Dec 1, 2008 10:23 AM
PinkStroker
67
Oct 25, 2008 10:55 PM
dwschmidt
Jun 16, 2008 07:20 PM
Leonandlisa
6.4L Power Stroke Diesel
13
Aug 12, 2007 11:46 PM
