1988 F-150 5.0 EFI Muffler question
I recently got my grandfather's truck for my son. Naturally he wants it to be louder and deeper sounding than it is now(all factory original)
I am looking for an inexpensive DIY way to make it sound good but stay legal, Don't have a welder or a shop so it needs to be clamped and doable in the driveway
If you have to do emission inspections, get a high flow catalytic converter and an aftermarket muffler like a flowmaster 40 series or a more generic version that is cheaper.
The other, less legal option if you don't have inspections is to just remove the muffler. The cat is a pretty good muffler by itself.
If the truck sat for a couple years and didn't get run, the rings were probably set in the block and when it got started again it broke them loose so that was probably a poor decision.
on
+1 Take a sawsall to it just behind the cats, drop the whole rear section and replace it with a turndown. Believe it or not that will produce a nice rumble at idle but it'll still be remarkably quiet driving around.
Actually when my stock muffler finally came apart, I cut pipe off, slipped a cherry bomb on it and made a 90* bend out the side(about middle of bedside). It has a nice rumble going down the road, but not obnoxious. It's basically a resonator for the cats.
Since the tailpipe is short, you DON'T get that machine gun kelly rattle when you stomp on it. It would have to be quieter then just a cat? I don't hot rod mine, so it isn't a problem anyway. 1989 F150 302/aod.
I welded mine up, but you can slip/clamp it too.
If keeping the stock cats, straight pipe or glass pack is the only way to get any sound out of it. I'd keep a tailpipe though. I personally hate the hollow tin can sound of Flowmaster. With stock cats, a Flowmaster will be barely louder than stock. The factory cats do a good job of muffling the exhaust. Rather than a cheapo glasspack, get a Dynomax bullet muffler.
MrRogers
05-11-2010 04:42 PM
