6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Motor Tech Question?!?
Old Mar 27, 2012 | 12:46 PM
Finz250's Avatar
Finz250
6.4 has been making a slight knocking noise at the beginning of acceleration and up to about 1500 rpm. Then it either stops or is being drowned out by road noise - cant tell. Ive had it at the dealer three times in a month. First trip they said all was good - a normal sound. Second time they werent so sure so they kept it 2 days and checked the motor over including compression tests on all cylinders. All checked out fine. They said 2 of the injectors were louder than the rest and chalked it up to injector rattle. A week later the engine light came on so that called for a third trip. I had a stuck egr valve which was replaced. The knocking is still there. The truck runs fine and always has but I cant stop thinking that it may be a more serious valve train type problem. My question is this - would compression test reveal a potential valve train issue and if it is just injector rattle - is that as normal as my service dept says it is? ANY INPUT IS WELCOMED! THANKS
Old Mar 28, 2012 | 05:07 AM
senix's Avatar
senix
Compression test could reveal a leaky or burnt valve.
Part of your issue maybe the newer flash. It changed several things and so the motor appears to be louder at times, even on mine.
So unless you have some other concerns I don't think there is an issue at this time.
Old Mar 28, 2012 | 08:09 AM
Finz250's Avatar
Finz250
Thanks senix. They also told me that the noise stopped when they went through and turned each injector off one by one. (that's why they said a couple of em were louder than the rest). How do they disable each injector? Is this with a computer or a manual procedure?
Old Mar 28, 2012 | 08:20 AM
senix's Avatar
senix
they do it with the computer they are using.
Old Mar 28, 2012 | 12:26 PM
Finz250's Avatar
Finz250
So in your opinion, they can make a good determination of whats going on deep within the motor without actually tearing it down? Would it be worth another dealer taking a look or will they perform the same diagnostics? Its warrantied for another 48k so i guess if it all goes south - it will be on ford, but i really dont want to see that happen.
Old Mar 28, 2012 | 01:41 PM
senix's Avatar
senix
unless you have another symptom probably wasting your time for now, imho
Old Mar 28, 2012 | 03:41 PM
Finz250's Avatar
Finz250
Thanks alot for your advice. btw - do you use or recommend any type of fuel additive that may help prolong engine or injector life? I didnt know if that would help or hurt or neither.
Old Mar 28, 2012 | 04:10 PM
senix's Avatar
senix
I don't use a thing to tell you the truth...but the motorcraft PM22 I think is recommended.
Old Mar 28, 2012 | 05:13 PM
R-T0r21on's Avatar
R-T0r21on
Pick yourself up some Diesel Kleen from Walmart. It's cheap insurance in my opinion. The Diesel Kleen may not be "the best", but it is easily available at any Walmart and many other places, and it is "very good" (and priced right too).
Fordenthusiasts
20
Oct 8, 2015 09:17 PM
Finz250
Mar 23, 2012 07:15 AM
repchris
2009 - 2014 F150
May 15, 2010 09:25 AM
flatbedstroker
13
Apr 15, 2009 07:40 AM
Roadhog123
Oct 28, 2003 03:48 PM
