Exhaust brake
Old Mar 27, 2012 | 09:02 AM
nateairman's Avatar
nateairman
Exhaust brake
I am using my ebpv for an exhaust brake and it leaks a lot from the shaft by the lever. Has anyone rebuilt one? If so what parts do I need?
Old Mar 27, 2012 | 01:14 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exhaust Back Pressure Valve Actuator Seal Repair Kit
(Ford) 2C3Z-9P466-BA (94.5-97)
(Ford) 2C3Z-9P466-AA (98-02)
here is a link
https://www.ford-trucks.com/forums/1...bout-ebpv.html
Clay has this number for 94-97:
2C3Z9P466BB IDK
Old Mar 27, 2012 | 10:56 PM
nateairman's Avatar
nateairman
It is leaking exhaust making a whistling noise...
Old Apr 1, 2012 | 01:09 PM
Ford4Life7.3's Avatar
Ford4Life7.3
The lever isn't controlled by exhaust gasses, its controlled by oil. If your hearing an exhaust leak from around the EBPV, check the clamp that holds the down pipe on. Mine is loose right now, and its causing that and black soot to go everywhere.
Besides that, check your Y pipe and the boots that go into the intake plenums, they could be loose/leaking and your hearing that.
Old Apr 2, 2012 | 11:16 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Agree with that. Also check the union between the turbo and up pipes.
Old Apr 2, 2012 | 07:12 PM
ReBilld's Avatar
ReBilld
I think he's talking about the shaft that goes through the turbo housing that the flapper is on. It has two bushings, one on either end. Using it as an exhaust brake is working that shaft alot more than normal operation as an EBPV. The bushing is probably worn around the shaft. Take the linkage lose from the flapper and see if you can wiggle the shaft any.
Old Apr 2, 2012 | 07:45 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Good call, and maybe you are right.
Old Apr 2, 2012 | 09:19 PM
nateairman's Avatar
nateairman
wiggles like mad and am hoping there is a kit or part#'s
7 mos old in lap gotta go!
Old Apr 2, 2012 | 10:03 PM
ReBilld's Avatar
ReBilld
I didn't see any part #s in the sticky at the top of the forum page, maybe call Ford and see what they come up with. Until then , if you could find another turbo and unbolt the section with the flapper in it and replace yours with that one, it would be a quick fix and give you time to get yours rebuilt without your truck being down.
Old Apr 4, 2012 | 09:50 PM
ReBilld's Avatar
ReBilld
Did you ever find the parts for your EBPV?
Old Apr 4, 2012 | 10:16 PM
nateairman's Avatar
nateairman
Not yet guys first concern is getting Jim my cores, then t500, then ebpv. One of my friends has a BD for a dodge that I was going to look at for ideas on rebuilding mine.
Old Apr 4, 2012 | 10:30 PM
ReBilld's Avatar
ReBilld
Yesterday,I was looking at the shaft and bushings that came out of mine when I deleted it. The butterfly valve (flapper) is attached to the shaft with rivets. You'll have to grind those off to get the shaft out and I guess you could re-attach it with bolts. The bushings that came out of mine still fit decent on the shaft and could maybe be reused. If you don't find any replacement parts, and if you think it would be worth it to put used stuff back in it, I'll send you the stuff out of mine.
Rudiak
6.4L Power Stroke Diesel
Nov 9, 2015 07:14 PM
scatgo
Dec 5, 2007 10:22 PM
rufaast
Jan 26, 2006 07:41 PM
Lobstah
Jul 17, 2003 01:52 PM
Gary E K
Nov 17, 2002 06:15 PM
