Water Pump; how much play?
Old Mar 25, 2012 | 11:28 PM
White 99's Avatar
White 99
Question Water Pump; how much play?
I had the belt off my truck and checked the water pump for play. I guess I really don't know how much is too much. I probably have a 16 of an inch, maybe less, up and down. What is the normal? Should I be looking to replace this one? No leaks yet.
Old Mar 26, 2012 | 12:45 AM
PaysonPSD's Avatar
PaysonPSD
No play is the norm. Keep an eye out for a leak from the weep hole.
Old Mar 26, 2012 | 01:29 AM
PaulDH's Avatar
PaulDH
If you've got 1/16" movement, I would plan on preparing it at your first convenient opportunity. Sounds like the bearings are going out and then it will probably start leaking coolant soon.
Old Mar 26, 2012 | 07:14 AM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
replace it now while its easy!
Old Mar 26, 2012 | 07:17 AM
Krazymaan's Avatar
Krazymaan
If you want it to last 150k plus get an oem pump, if you like changing them out every few years, get one from an auto parts store
Old Mar 26, 2012 | 12:22 PM
PaysonPSD's Avatar
PaysonPSD
Best price I have seen for an OEM water pump. Riffraff Diesel
Old Mar 26, 2012 | 04:57 PM
big poppa's Avatar
big poppa
Got mine from Clay, best price plus buying from Clay is supporting here, good guy too. Mine started to weap a bit and for a 150.00 its just worth it than paying for a catastropic failure, fan blade letting loose and taking everything in front of it, rad, cooler, exct. Replaced mine at about 175,000, stock unit, says alot.
Old Mar 26, 2012 | 06:16 PM
PaulDH's Avatar
PaulDH
Not to be the spoil sport, but my factory water pump went bad recently with 85K miles. The pump shaft shifted forward toward the radiator until the pump vanes/impellers were contacting the adjacent stainless steel plate. I replaced it with an Airtex. Figured the Airtex would probably last as long as the factory pump lasted.
Old Mar 26, 2012 | 10:27 PM
White 99's Avatar
White 99
Thanks for the replys. I guess I will have to schedule a new one. I will probably get the oem from Clay. 100,000 miles on this one. I need to order some other stuff also.
I guess I should check the play on a new one so I will remember.
Old Mar 27, 2012 | 11:38 PM
novice psd's Avatar
novice psd
Airtex is the supplier for OEM. My water pump went at 60,000.
Old Mar 28, 2012 | 12:08 AM
PaulDH's Avatar
PaulDH
In that case, buy an Airtex for ~$85. That's about what I paid for mine.
Jollygr33ngiant
Jan 7, 2016 04:23 PM
Epd444
Apr 26, 2012 11:18 AM
CharGriller
Apr 6, 2009 07:26 PM
wheressinatra
Oct 16, 2006 05:28 PM
RockinB
Dec 22, 2003 10:04 PM
