Primer question
Old Mar 25, 2012 | 07:15 PM
dualwheels66's Avatar
dualwheels66
Primer question
I have a Reading truck cap that I am repairing to put on my truck. ReadingBody.com | Commercial Caps | Commercial Caps
The one I have now is red and my truck is green, so I will strip it down to bare metal in sections as time allows and prime it with rattle can primer, rust oleum, to prevent flash rust while it sits around. So my question is when it comes time to spray the whole thing do I have to strip off the rattle can primer or is there a primer I can use to spray over the rattle can primer or some kind of bonding agent or other options. Thanks for your help.
Old Mar 25, 2012 | 09:32 PM
Sand_Man's Avatar
Sand_Man
Rattle can primer is neither rust proof or water resistant. It offers zero protection at all and bare metal will rust underneath it. You need a catalyzed primer which needs to be shot through a gun.
Old Mar 25, 2012 | 09:58 PM
dualwheels66
I am going to shoot primer out of a gun, I need to know if I can cover over the rattle can primer or do I need to take the rattle can primer off?
Old Mar 26, 2012 | 07:37 PM
Sand_Man's Avatar
Sand_Man
I've never done it before, but that doesn't mean it can't be done. I strongly suspect a quality primer would wrinkle the spray can stuff, but maybe not. I've always looked at paint jobs like building a house in the sense that it's only as good as the foundation. You may get away with it, but then again you may get the whole truck painted only to have the paint lift, peel and wrinkle over the area that was done with rattle can primer. I'd take it all the way off myself.
Old Mar 26, 2012 | 08:16 PM
dualwheels66
Ok thanks, how would I protect the bare metal until I spray it with primer?
Old Mar 26, 2012 | 09:39 PM
Sand_Man's Avatar
Sand_Man
If you're working on the truck and driving it at the same time, you really need to shoot a good epoxy primer. Epoxies are weather resistant for a long time and will do fine. But if you're lucky enough to have another vehicle to drive while you work on your truck in the garage, try this stuff Eastwood Metal Wash
Old Mar 27, 2012 | 07:39 AM
graphicjunkie's Avatar
graphicjunkie
No no no!!
Don't ever try to lay down a coat of rattle can, and then cover it with catalyzed uro ('urethane' paint is the standard for most of the current automotive refinish paint systems) primer...or uro anything. The two systems are NOT COMPATIBLE and you will end up with problems down the road.
If you want to protect it... Picklex 20.. the only way to go.
Picklex20 Manufacturer Home Page Metal surface preparation, steel pre-treatment.
Old Mar 27, 2012 | 06:15 PM
dualwheels66
Sandman, the cap is sitting in my back yard up on horses and I work on it when I have the time. That's why I need something to protect until I can prime and paint properly. My truck right now has a aluminum cap that is a piece of crap(leaks). I will swap caps when the Reading one is done.
Graphicjunkie Thanks for the link. That looks like good stuff.
Old Mar 28, 2012 | 07:52 AM
graphicjunkie
Also want to clear up a mis-conception. Most primers are not meant to be a moisture barrier. That's what the sealer is for. Primer is meant to be a build layer to help you smooth out any last little imperfections in the panel. That's it. You do your body work, prime it block sand it to straighten everything up, prime it again for any touch up work, block it again, and then seal it with a good sealer. The exception to this rule is a primer/sealer like PPG's DP40LF series. As I'm sure there are other brands out there that do the like. But if you do it that way, just make sure that your product will act as both.
Old Mar 28, 2012 | 08:08 AM
Grubbworm's Avatar
Grubbworm
You are absolutely correct about most primers not being a moisture barrier. Although, a good quality 2-part epoxy primer is when mixed and applied correctly. It is probably one of the best things that you could use on top of well prepared bare metal, before you use any filler.
Old Mar 28, 2012 | 08:47 PM
dualwheels66
I think I will go with a epoxy primer and a sealer, so what brands of primer and sealer should I use? Are these products easy to order and easy to apply? Thanks
Old Mar 28, 2012 | 10:55 PM
Sand_Man's Avatar
Sand_Man
Don't just pick a brand of primer, pick a whole "system" of the same brand. Manufacturers design their stuff to work together with no goofy problems as long as you use their stuff from primer to clear. Personally I like House of Kolor for custom jobs and DuPont for factory matches because that's what my local store sells and they treat me well. Ask your local paint store what they recommend.
Old Mar 29, 2012 | 08:05 AM
graphicjunkie
Also, don't forget to talk to your jobber about paint code color compatibility. Some paint codes require specific color/tone undercoating to achieve the correct shade. I've seen some really crazy combinations over the years. You don't just want to pick one because of your mood. lol.
Old Mar 29, 2012 | 03:32 PM
dualwheels66
Yes I was thinking about using the same brand of primer and paint, just for the simple reason that it will be color matched to my truck. Thanks for the help.
Old Mar 29, 2012 | 07:14 PM
Sand_Man's Avatar
Sand_Man
My local DuPont dealer uses the VIN of the vehicle I'm painting to get a perfect combo of primer, base and clear to match what it came off the factory line with. So far I have never had a problem with color matching.
02GrayPowerStroke
Feb 11, 2007 03:11 PM
marty68
Paint & Bodywork
May 31, 2006 06:00 AM
hernando
Paint & Bodywork
Feb 24, 2004 11:48 AM
Fully_Loaded
Paint & Bodywork
Feb 13, 2004 10:33 PM
dj53
Dec 20, 2003 05:00 AM
