Differential Tag Decode
Old Mar 23, 2012 | 09:13 PM
koski19's Avatar
koski19
Hey Guys,
I serviced the rear differential and was curious about the tag numbers.
Here they are:
S 409 B
3 L73 105 8B03
Any insite would be appreciated. The other tag reads 75W-140 synthic oil only.
Jeff
Old Mar 23, 2012 | 09:25 PM
woodnthings's Avatar
woodnthings
3L73 105 = 3.73 limited slip 10.5" Ford Rearend.
Old Mar 24, 2012 | 08:35 AM
koski19's Avatar
koski19
Smile
Hi Ken,
Thanks for the info and reply. I read that you installed the 2nd Gen Frx mod. What was the most noticable difference after you installed?
I'm thinking of installing one as my next mod. I have installed the 6637 filter and oil tube crossover. From those two mods the engine is smoother and the fuel mileage increased.
Thanks Again,
Jeff
Old Mar 24, 2012 | 10:56 AM
woodnthings
With the FRx you will notice the cackle goes away. It is designed to purge the air that can be introduced into the fuel system a return path to the tank. The stock system forces it through the injectors, which can damage them. It is a very nice system and is the lowest cost for a regulated return that you will find, that makes it a hit to me.
Old Mar 24, 2012 | 02:47 PM
PaysonPSD's Avatar
PaysonPSD
Here's an example from my truck on how to decode the diff tag.
The codes on my rear differential tag are:
S409B
3L73 102 8C11
The break down of these codes:
S409B:
S = Sterling Differential
409 = Print Number (Model Number)
B = Revision Identifier (Change in Design)
3L73:
3L73 = 3.73 Ratio
L = Limited Slip
Absence of L = Open Differential.
102 denotes the ring gear size. 10.25 inches. 105 would be a 10.5 inch ring gear.
8C11 is the build date.
8 = year of manufacture. In this case it means 1998.
C = month of manufacture. A= January, L= December so C= March
11 = day of manufacture. So My differential was manufactured on March 11, 1998
Old Mar 24, 2012 | 02:51 PM
woodnthings
Nice Job Robin!
Old Mar 24, 2012 | 04:09 PM
PaysonPSD's Avatar
PaysonPSD
Thanks Ken.
As far as I can tell I first posted that in April, 2008.
Old Jun 19, 2021 | 02:42 PM
TX_Jax's Avatar
TX_Jax
https://itstillruns.com/read-ford-tr...g-7735023.html
koski19
16
Jan 7, 2013 02:42 PM
joe blow
Jul 13, 2009 10:14 AM
05f250fx4
Sep 6, 2006 06:01 AM
rosa70
15
Apr 20, 2006 09:15 AM
fd1109
Feb 12, 2006 12:09 PM
