Horrible Cab Mounts question!
Old Mar 23, 2012 | 12:09 PM
68cabby's Avatar
68cabby
Unhappy Horrible Cab Mounts question!
Alright, in my almighty endeavor to get my truck back up and going, there has forever been an ongoing problem..the horrible cab mounts. Now, Both of the supports on the cab went soft in the bottom, and the passenger side is by far the worst, and when you look at my truck, it actually sits 2.5 to 3 inches lower. Would the cab mount be responsible for this front end lobsidedness? would it cause everything up front to be lopsided? Because I thought there was another set of moounts by the radiator core support, and they're just fine.
Old Mar 23, 2012 | 12:25 PM
68cabby's Avatar
68cabby
Oh, and if you go to my profile and look in my album, you can see the front shot of the truck i'm talking about, pretty sure i can't attach photos, so thought if you guys were curious, there it is.
Old Mar 24, 2012 | 01:36 PM
7283-F250's Avatar
7283-F250
From the pictures I saw it looks like the front right (pass) radiator support is bad. Or the frame is bent.
The marker light should not be covered by the bumper.
Look at it from the under side. The mount bolt might still be there and the frame rotted through. My '68 has signs of the rad support mount hole getting bigger from rust/rot. If it gets to big the rubber mount will fall right through. My '72 had the radiator mount rotted and the frame was fine so that was visible from the top side.
Old Mar 24, 2012 | 03:10 PM
68cabby's Avatar
68cabby
Well..ive checked em..the frame is fine and the.supports arent terrible. Theres some rut but not rot. The pass cab mount is the worst and its sunk all the way through.
Old Mar 25, 2012 | 07:28 PM
68cabby's Avatar
68cabby
Well, I did some looking around the engine compartment...and a second set of eyes did confirm that it is indeed the core support mount..never wouldve thought haha. That, and a combination of the cab mounts sure aint helpin! So now, I gotta look into getting another core, and a pass side inner fender..
Old Mar 28, 2012 | 01:57 PM
7283-F250's Avatar
7283-F250
Glad to see you figured it out.
FYI you can use 73-79 core supports but you do need to drill a few holes for the inner fender mount. I'm not exactly sure where the holes need to be drilled.
brendo613
Jun 12, 2011 09:49 AM
ford-harto3457
Apr 5, 2009 12:53 AM
JOSEPHU
Feb 21, 2008 09:56 AM
Drac
Feb 26, 2007 08:21 PM
bluestang65
Feb 20, 2005 10:45 AM
