Rear U-Bolt Vendor...
Old Mar 21, 2012 | 02:21 PM
56FOneHundred's Avatar
56FOneHundred
Quick question. I recently rebuilt the rearend of my truck and in the process I removed 3 leaves from each stack. I purchased u-bolts from Mac's and when I received they first sent me 3 matching bolts and 1 mismatching bolt, but the all had the same stock number. when I tried installing them none of the 4 had enough thread on the bolt to tighten down the springs to the axle. Can anyone give me a heads up on where I can order some u-bolts that will fit now that I have removed leaves and made the spring shorter?
Old Mar 21, 2012 | 02:34 PM
Mervy49's Avatar
Mervy49
I don't know were you are located but here is a place that has all the U bolt you can imagine, you might want to give them a try. Otherwise, most trailer maufactures can supply U bolts.
U-bolts Custom & U-bolts Standard
Old Mar 21, 2012 | 03:17 PM
Harrier's Avatar
Harrier
I called a local machine shop and they directed me to a company in my town that worked with big truck and they made me some u-bolts for my F-250 rear. They couldn't make my front ones because they didn't have a small enough die.
Depending on where you live, you might have a place that will make custom u-bolts for you.
Old Mar 21, 2012 | 04:22 PM
Tyler S's Avatar
Tyler S
Mine came from TCI in so cal.
Old Mar 21, 2012 | 06:14 PM
harleymsn's Avatar
harleymsn
When I needed custom Ubolts for my flatbed, the guys at Suspension King in Pa. did me right.
Suspension U bolts (Round Bend) - TheSuspensionKing.com
Old Mar 21, 2012 | 06:17 PM
oldmerc's Avatar
oldmerc
oldmerc
Any spring shop should be able to make them up for cheap .
Old Mar 21, 2012 | 08:43 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Yep, about $5 apiece and made while you wait. Take your spring plates along to make sure they bend the u-bolts fully, and the U-bolts fit thru them.
Old Mar 22, 2012 | 08:25 AM
55 f350's Avatar
55 f350
or put some more thread on 'em and whack 'em off too length . i do things the hard way though so pay no attention to me ...............Name:  2077.gif
Old Mar 22, 2012 | 07:14 PM
GLR's Avatar
GLR
As 55 says. Even if you have to buy a die (NOT a re-threader). Or check with a local repair shop to see if they can cut more threads. Or, check with local High or Vocational school. Some have machine shops or auto repair shops.
No need to buy any more u bolts.
brooksbronco17
May 14, 2013 01:18 PM
puck1263
13
Feb 10, 2013 07:12 AM
freakdaddy
Jul 30, 2009 02:47 AM
camccardell
Sep 4, 2008 07:26 PM
Cheshire Cat
1966 - 1977 Early Broncos
Mar 23, 2004 06:48 PM
