I did need a new bolt for the center. I just ground the points off a regular 3" bolt and that looks like it will work.
Front spring eye and hanger holes get drilled out with a 3/4" step drill bit and extension for 3/4" 5" long Grade 8 bolts and nuts
I've got velvet shackles on the rear so the SD rear bolts will work. If reuseing OBS schackles it would need drilled out because the OBS bolt is smaller. Looks like springs alone will raise it an inch or so in the back.
Got them both in. I used grade 5's in the front but will get 8's in there soon. It raised the back end up about an inch so now I think a D60 with 2.25 rsk will level it good.
