High exhaust temp
Old Mar 21, 2012 | 06:02 AM
dmanshane's Avatar
dmanshane
High exhaust temp
Last weekend I Was pullin a gooseneck stock trailer and I was goin into the wind I was empty too I had to run stock setting and foot too the floor I was runnin 1000 deg and 22 psi boost fifth gear 2900 rpm she would t pull it in sixth but if I put my chiP On 50 it would pull just fine 80 mph but exhaust would run 1200-1500 I don't think that's good
Old Mar 21, 2012 | 06:19 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
What chip you running? I would look for leaky uppies.
Old Mar 21, 2012 | 07:29 AM
dmanshane's Avatar
dmanshane
Ts with stock high idle 50 75 100 140 tunes
Old Mar 21, 2012 | 07:32 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Look for soot around your up pipes and maybe check for boost leaks too.
Old Mar 21, 2012 | 07:34 AM
dmanshane's Avatar
dmanshane
I have a torn intake boot but still can get 20 psi boost if I go higher I'll blow the tube out I have a boot set ordered from clay
Old Mar 21, 2012 | 07:38 AM
dmanshane's Avatar
dmanshane
I am hopeing to get a 38r soon and I hope that will help with the temp too
Old Mar 21, 2012 | 07:43 AM
timmyboy76's Avatar
timmyboy76
Not good man. Ask'n for a turbo disaster/motor, if thats the case...(dusting)
Old Mar 21, 2012 | 07:45 AM
dmanshane's Avatar
dmanshane
It's after turbo first one after spider I'm drivin my old gasser chevy
Old Mar 21, 2012 | 07:46 AM
bfife's Avatar
bfife
still plays with trucks
No dusting from a torn intake boot, cause all the pressure is blowing out, not sucking in. and yes a torn boot will cause high EGTs
Barney
Old Mar 21, 2012 | 07:48 AM
dmanshane's Avatar
dmanshane
Ya I'm nOt worried about it
Old Mar 21, 2012 | 07:49 AM
timmyboy76's Avatar
timmyboy76
With his last post, now i know what 1 he's referring to. Original post sounded like the one that connects the intake where ccv is...
dmanshane
Dec 12, 2011 09:36 PM
tjbeggs
Oct 24, 2007 07:40 PM
none2
May 12, 2007 08:41 PM
1997F-350
Jul 1, 2005 09:05 AM
philn
Nov 5, 2003 11:12 AM
