High EGT's
Old Nov 4, 2003 | 04:01 PM
philn's Avatar
philn
High EGT's
Just finsihed installing Pyro and Boost gauges and much to my surprise - it's too high! Running the Diablo 60 HP tune gets to 1200 degrees at WOT. Too much for my comfort! I got nervous about it and bumped down to the tow setting (40HP). At that setting it runs about 900 at WOT. Is this normal for stock exhaust? I didn't think the EGT's would be that high on the 60HP setting. I guess it's time for 4" exhaust. I highly recommend the pillar pod and gauge set. Looks great and will no doubt help in the long run. I put in the Isspro set for about $215.
Old Nov 4, 2003 | 04:16 PM
DCSpecial's Avatar
DCSpecial
Where is the thermocouple located?
Old Nov 4, 2003 | 04:54 PM
philn's Avatar
philn
Pre Turbo just below exhaust manifold on drivers side.
Old Nov 4, 2003 | 06:15 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Your EGT's are completely normal for stock intake and exhaust with a chip.
Old Nov 4, 2003 | 07:07 PM
philn's Avatar
philn
Ok, thanks. Time for 4" exhaust I guess.
Old Nov 4, 2003 | 07:36 PM
DCSpecial's Avatar
DCSpecial
Yeah, what cookie88 said .......over 1300* would be too high.
Old Nov 4, 2003 | 10:17 PM
f350xlt460's Avatar
f350xlt460
would 900 be to hot post turbo, 4 inch exhaust and 60 hp diablo tune?
Old Nov 5, 2003 | 06:28 AM
powerstroker250's Avatar
powerstroker250
There is no correct answer for this, some with dual pyros have seen a variance of 100-500*F from preturbo readings.
Old Nov 5, 2003 | 07:21 AM
f350xlt460's Avatar
f350xlt460
well, it was on a hard pull up hill pulling a 7000 lb boat in 4th gear. Guess i should mount it pre turbo for more reliable readings.
Old Nov 5, 2003 | 08:30 AM
domslude's Avatar
domslude
From what i have read with a chip and only 3 in exhaust 1200 is normal. If you get above 1400 bully dog says it's too hot. but if you add a four or five inch exhaust your temps should drop to below 1000. Then you can really turn up the juice and have fun.
Old Nov 5, 2003 | 11:12 AM
cookie88's Avatar
cookie88
FTE Emeritus
I would guess 1000-1100 pre turbo. High rpm's in lower gears tend to keep the exhaust temps down.
