Here is a pic of the whole lower control arm on the passengers side...
[/IMG]
In this picture you can see there is a gap between the control arm bushing and the back of the control arm mounting bracket. I'd say its about 3/32". The control arm on the driver's side fits snugly/flush. There are no extra spacers on the DS arm or anything like that. Is this a problem or can I just take up the distance with an extra washer? [/IMG]
Uhhh....I don't know. The ball joints have grease fittings, but as far as the bushings I don't know. I have another post on here called "to lube or not to lube...that is the question" where I ask what I should lubricate. That's all I've got. Cranking it down with the bolt would be preferable to shimming it with a washer?
I would call the manufacturer of the kit. If that's not an option, talk to a good front end man. Personally, I don't like the gap. I think you would have to crank way too tight on that A-arm to pull it that far. Just my opinion.
OK, problem solved. The TCI instructions were pretty vague, but I talked to the shop and they intend for there to be a washer on both sides of the rear bushing on the lower control arm. So I put in the washer and the gap is fine. The driver's side was very, very snug without the washer, but I still had to get it in there. That was a real wrestling match for which I had to tap out and get some professional help. Pete from the "Old Ford Store" here in Tucson made a house call and showed me how to shoe horn it in there. My son and I fought with that washer for over an hour and made no progress. Pete did it in about 90 seconds The difference between an amateur and a pro.
Here is a pic of the passenger's side with the gap closed:
