Sponsored by: Auxito
front upper control arm bushings
Old Oct 14, 2008 | 08:55 AM
svt4cobra6's Avatar
svt4cobra6
Looks like the front upper control arm bushings are a bit worn, just wondering if it is easier to replace the entire control arm, think they are 60 each or take out the old ones and replace the bushings?, looks like they are pressed in.
Old Oct 14, 2008 | 10:44 AM
Spotty's Avatar
Spotty
You won't get them out, the OEM's are pressed into the control arm. I just bought the whole control arm with the ball joint. If you buy a certain brand arm and balljoint, just the ball joint can be replaced in the future. If it's like my 98 the 2 upper bolts and nuts are in slots so you can set the camber-caster. Try to mark the control arm before you loosen them so you can get it close upon reassembly. Alignment is a must when done to be 100% correct. Be sure not to tighten stuff 100% until it's back on the ground at it's normal stance or the new bushings will bind. Hope this helps...
Old Oct 14, 2008 | 08:57 PM
svt4cobra6's Avatar
svt4cobra6
thanks for the information, just wondering what control arms you used.
Old Oct 15, 2008 | 06:52 AM
Spotty's Avatar
Spotty
I got them at O'reilly's or NAPA, do not remember, but they were Dorman. They come complete, ready to bolt in. The ball joint is not replaceable as a seperate item on the Dorman either. I think Moog is the only one. I like the idea of it all being new anyway. Here is a picture of one, I have bought stuff from here before, not a recommendation or promotion for this company, thought the picture might help. Northern Auto Parts: - Dorman Control Arms for Fords
Old Oct 15, 2008 | 01:16 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
What year and model is your truck? Is it a 4x2 or 4x4. Dan.
