Sponsored by: Auxito
Coolant Leak
Old Mar 17, 2012 | 09:45 PM
mcdev's Avatar
mcdev
Coolant Leak
Hey guys. The other day I was doing my usual monthly inspection of the truck. Since about turning over 200,000 miles the truck has been going through about a quart of oil every 5,000 miles and it has been increasing. That is fine; I have about 235,000 on the truck now and I suppose that is to be expected. What I did notice this last time though is that my coolant reservoir was very low. This has never been a problem before, in fact, the coolant is still nice and green despite not having been changed in 80,000 miles. So I was just playing around with it, trying to figure out where the problem is and noticed some coolant leaking down the backside of the engine when I looked up from underneath the truck. I can't locate the leak so I was hoping one of you guys could point me in the right direction. I am just happy my head gasket isn't blown, that was my biggest fear, and I really hope I am right about that. The truck is a 2000 F150, 5.4L, 235,000 miles, 4x4, automatic... Thanks guys!
Old Mar 17, 2012 | 10:19 PM
kbsupercrew's Avatar
kbsupercrew
possibly the two back coolant ports, one on each side after port 4 and port 8, these are dead headed ports or the pump steel line to your heater hoses
Old Mar 17, 2012 | 10:26 PM
kbsupercrew
this is your intake notice the dead head ports 4 and 8
Old Mar 17, 2012 | 11:06 PM
mcdev's Avatar
mcdev
kbsupercrew, thanks for the quick response... now whats the best way to get back there to check it out and then fix it?
Old Mar 17, 2012 | 11:26 PM
kbsupercrew
I use a telescopic inspection mirror and a good beam flashlight lean over the radiator and look right past coil 4 where the intake meets the head for intake gasket leak and then coil 8, then using the mirror look at the pump tube and the heater hoses, also look in the valley
Is the leak on driver or passenger?
Old Mar 18, 2012 | 12:03 AM
mcdev's Avatar
mcdev
Hard to tell as I can only see the fluid coming down from underneath where it looks like its all over... I will have to try again to see if I can determine which side it starts on before it spreads.
Old Mar 18, 2012 | 07:56 AM
critterf1's Avatar
critterf1
Have replaced many of those heater hose tubes due to rust.
Old Mar 18, 2012 | 08:24 AM
steve(ill)'s Avatar
steve(ill)
look in the VEE of the motor behind the alternator. See if you are full of antifreeze there. You can have a crossover tube gasket leaking in the front, and it will fill the VEE and run out the back onto the transmission case.
Old Mar 19, 2012 | 06:50 PM
mcdev's Avatar
mcdev
steve(ill), it looks like that might be the case... It appears that the leak is getting worse and it looks like it sprayed the passenger side, upper part of the motor (transmission dipstick, oil filler, ect...). Waiting for it to cool down so I can add some more water and start her up again to see where the leak is originating. Thanks for your help guys.
Old Mar 19, 2012 | 08:51 PM
steve(ill)'s Avatar
steve(ill)
https://www.ford-trucks.com/forums/8...d-on-5-4l.html
Old Mar 19, 2012 | 09:47 PM
mcdev's Avatar
mcdev
steve(ill), looks like you nailed it. The leak is right below what I believe is the heater hose coming into the top of the intake manifold. In that great post of yours that you linked, you mentioned using a leak stopper. Would you suggest using that in the short term? I intend to repair the problem properly soon, but as the truck is my only vehicle, I might need more than a weekend to get the job done. I will readily admit that I am a little intimidated by this task. I have done lots of different jobs on this truck, but I have never pulled the intake manifold off any vehicle let alone this one with the fuel rails, COPS, and everything else.
Thanks again, this place is awesome.
Srtwayne
Nov 30, 2017 08:53 PM
COVeteran
Nov 20, 2017 12:59 PM
cnelso48
Feb 21, 2010 05:40 PM
bla1879
S. California Chapter
Apr 22, 2009 01:01 PM
bla1879
Apr 22, 2009 12:56 AM
