Exhaust Mathemagic
The simple part:
- EGT (F) + 460
- Divided that by 540
- Multiply that by your intake CFM (turbo output)
- Equal total exhaust flow in CFM
Rules of thumb I've gleaned from the "experts": You want less than 1.5 PSI total back pressure from the whole exhaust system after the turbo (no sensor there). Figure 2.2 CFM per HP output on a normally asperated engine, but I'm too brainfried to look into the rule for a turbocharged engine. The right muffler is as good as a straight pipe - there is no need to go loud to get straight-pipe performance.
Questions: Does anybody know the CFM out of our stock turbos at sea level on a 60-degree day? Does this post lead anybody astray on working the math on an exhaust system? Has anybody worked out the back pressure of a straight-pipe system for 3.5" vs. 4" vs. 5"?
My hypothisis: 3 1/2" (stock) does just fine with just about everything except modding and/or heavy towing. 4" takes care of everything but mega-modding. 5" is needed for mega-modding, but is typically installed by the "If 4" is better, 5" should be great" crowd.
Oh.... This is my 500th post on FTE
