need some serious help
Old Mar 18, 2012 | 10:21 AM
HD Rider's Avatar
HD Rider
Hook up a cheap mechanical gauge to test/compare your sending unit on your electrical gauge. If the mech gauge reads significantly different, you know your sending unit is bad.
Old Mar 18, 2012 | 10:28 AM
timmyboy76's Avatar
timmyboy76
Harbor Frieght has cheap liquid fill ones, and i believe the bendable grease hose threads are compatable to the sensor threads..make a cheapo mech. set-up for 5 buks..
Old Mar 18, 2012 | 11:15 PM
7.3bo-ti-etr's Avatar
7.3bo-ti-etr
Thanks guys I just picked up my air compressor so ill be pushing some air through there tomorrow and recheck the FPR and caverjoe I may have to take you up on that offer ever since I've owned the truck (couple years now) its not really had the power it should so maybe the AE will see something I don't. Where are you located.
Old Mar 19, 2012 | 11:58 PM
7.3bo-ti-etr
Picked up the FPR rebuild kit and will be putting on tomorrow ill check back in after its on.
Old Mar 20, 2012 | 07:35 AM
caverjoe's Avatar
caverjoe
South end of Harrisonville. 3.5 south of 7 Hwy 2.5 east of 71hwy. PM me if you want and I will give you a call.
Old Mar 21, 2012 | 12:27 AM
7.3bo-ti-etr
So picked up the FPR rebuild kit today. Got it installed and the trucks running pretty good the psi is staying between 66-70 idle is smother than its ever been. The truck still fills slugish and lacking some power in my mind, but hopefully ill be meeting with caverjoe and get some data going.
Old Mar 21, 2012 | 07:41 AM
timmyboy76's Avatar
timmyboy76
Well thats good to hear/see...hopefully its all in ur mind.
Old Mar 21, 2012 | 11:48 AM
PaysonPSD's Avatar
PaysonPSD
Glad the FPR rebuild got the fuel pressure where it should be. It is an often overlooked wear item.
Old Mar 22, 2012 | 06:43 PM
caverjoe's Avatar
caverjoe
Andrew,
You may have to give me a little insight on this FPR rebuild. I will be working in Lotawanna tomorrow (fri) probably from 9-3 or so. Let me know if you want to meet up somewhere. Or give me a call before 9 tonight or sometime tomorrow.
Later
Old Mar 22, 2012 | 08:13 PM
caverjoe's Avatar
caverjoe
If one was to purchase the FRX. Would that eliminate the need for the FPR rebuild?
thanks
Old Mar 24, 2012 | 08:52 AM
HD Rider's Avatar
HD Rider
No you still need a woriking regulator.
VegasFordSD
13
Feb 28, 2014 06:29 AM
super10brss
Jan 3, 2012 03:19 PM
429 f-100
Jun 23, 2011 06:00 AM
deetown
Mar 20, 2007 09:29 PM
rbmstng
Jan 5, 2004 08:13 PM
