Sponsored by: Real Truck
F250 fluids??
Old Mar 16, 2012 | 03:36 PM
ohiof250's Avatar
ohiof250
F250 fluids??
Hello,
I just bought a 2000 f250 4x4
it has the 5.4 engine
it is auto
the truck has 55,000 origanal miles
I want to change all the fluids.
What is your recomenned fluids for the following.
rear and front axles, trans and transfer case.
Old Mar 16, 2012 | 04:59 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
For the transmission use MERCON V. Your choice on the brand.
Old Mar 16, 2012 | 05:47 PM
redford's Avatar
redford
FTE Leadership Emeritus
From your owners manual. You can download a copy at
http://www.motorcraftservice.com/pub.../00f23og3e.pdf
Mercon V is a replacement for Mercon, per the Ford TSB.
REFILL CAPACITIES
Fluid
Ford Part
Name
Application Capacity
Front axle Motorcraft SAE
75W-90
Premium 4x4
Front Axle
Lubricant
F-250/350 Dana
50 axle
1.8L (3.8 pints)
F-350/450/550
Dana 60 axle
2.7L (5.8 pints)
Rear axle
1,2
Motorcraft SAE
75W-140
Synthetic Rear
Axle Lubricant
F-250 /350
(10.50 inch
axle)
3.3L (6.9 pints)
Motorcraft SAE
80W-90
Premium Rear
Axle Lubricant
F-550 Dana 135 11.6L
(24.5 pints)
Brake fluid High
Performance
DOT 3 Motor
Vehicle Brake
Fluid
All Fill to line on
reservoir
Capacities and specifications
222Fluid
Ford Part
Name
Engine coolant
Premium Engine
Coolant
5.4L V8 engine
without A/C
16.9L
(17.9 quarts)
5.4L V8 engine
with A/C
18.4L
(19.4 quarts)
6.8L V10 engine 29.0L
(30.6 quarts)
Engine oil
(includes filter
change)-Gas
engines
Motorcraft SAE
5W-30 Super
Premium Motor
Oil
All 5.7L
(6.0 quarts)
Engine oil
(includes filter
change)-Diesel
engine
Refer to your 7.3L Diesel Supplement
Fuel tank N/A Mid-ship tank
(optional aft
axle on narrow
frame Chassis
Cab)
71.9L
(19.0 gallons)
Right side
saddle mounted
tank (optional
on narrow frame
Chassis Cab)
87.1L
(23.0 gallons)
Short box (wide
frame Regular
Cab)
109.8L
(29.0 gallons)
Long box wide
frame (Regular
Cab, Super Cab
or Crew Cab)
143.9L
(38.0 gallons)
Aft axle (narrow
frame Chassis
Cab)
151.4L
(40.0 gallons)
Power steering
fluid
Motorcraft
MERCON ATF
All Fill to line on
reservoir
223Fluid
Ford Part
Name
Transfer case
fluid
Motorcraft
MERCON ATF
4x4 vehicles 1.9L
(2.0 quarts)
Transmission
fluid
Synthetic
MERCON ATF
5-speed manual 3.2L
(3.4 quarts)
Motorcraft
MERCON ATF
6-speed manual 5.5L
(5.8 quarts)
Automatic 16.7L
(17.7 quarts)
Windshield
washer fluid
Ultra-Clear
Windshield
Washer
Concentrate
All 4.0L
(4.25 quarts)
(Well, the formatting sure didn't work)
Jimbob8
Dec 21, 2011 08:52 PM
caseydudem
Sep 24, 2009 06:04 PM
John K
Jun 6, 2007 05:50 PM
ssjrsw
May 30, 2007 10:38 PM
SoundBuys
Jul 22, 2004 03:34 PM
