Fluid amounts and types
Old Jul 22, 2004 | 12:35 PM
SoundBuys's Avatar
SoundBuys
I recently purchased a 2000 PSD F250, I have done one oil change on it so far and replaced the fuel filter. I was going to do the other fluids on the truck but I do not have the fluid weights or amounts. ( I know it is in the manual but when I got the truck he was missing the diesel suplement).
Any help would be great! I am looking to change
Tranny fluid (manual trans)
front and rear diffs
coolant
and anything else that people would recommend!
Shawn
Old Jul 22, 2004 | 01:11 PM
TOPFLOR's Avatar
TOPFLOR
manual tranny......... mercon automatic transmisison fluid(that's what i t says for manual)
3.4 qts(5 spd)
5.8 qts(6spd)
coolant.......................50/50 mixture of ethylene glycol based antifreeze and distilled or demineralized water.(EVANS is a popular brand)
front axle.....SAE 75W-90 QL synthetic gear lubricant
rear axle...SAW 75W-140 GL syn gear lube(10.5"..which is what a '00 single rear wheel has)
dana 80 axle....75W-90 QL synthetic gear lubricant
dana135 axle....80W-90 QL synthetic gear lubricant
change/bleed brake fluid with any heavy duty DOT 3 product
power steering fluid is mercon atuo tranny fluid
transfercase(4x4) is mercon tranny fluid(again)
Siyé
Old Jul 22, 2004 | 01:20 PM
wlihntr's Avatar
wlihntr
coolant
Shawn
transmission:5-speed manual: synthetic mercon ATF, 6-speed manual: mercon ATF
5-speed=3.4 quarts
6-speed=5.8 quarts
front axle 75w-90 premium axle lube
rear axle 75w-140 high performance synthetic axle lube(add 8oz friction modifier "c8az-19b546-a" on traction-lok axles)
coolant-standard green coolant(must add coolant additive "FW-15" every 15,000 miles on diesel engines)
Old Jul 22, 2004 | 01:44 PM
HeatStroked's Avatar
HeatStroked
Go here to get a free owners manual from Ford:
http://www.genuineflmservice.com/default.asp?page=E4
or here:
https://www.ford-trucks.com/faq/9497faq/download/2001/
Old Jul 22, 2004 | 02:48 PM
SoundBuys's Avatar
SoundBuys
thanks guys.... I suppose that i need to get the FW16 at a Ford dealer?
Shawn
Old Jul 22, 2004 | 02:52 PM
wlihntr's Avatar
wlihntr
Shawn
yea the dealer has it, i forgot its called fw-16 now
Old Jul 22, 2004 | 03:20 PM
SoundBuys's Avatar
SoundBuys
5-speed=3.4 quarts
6-speed=5.8 quarts
How much coolant is needed?
Also how much in the front and rear axels and transfercase ?
Old Jul 22, 2004 | 03:34 PM
wlihntr's Avatar
wlihntr
total cooant capacitiy is 32.75 quarts. additive is one bottle every 15,000 miles(i think its 8 oz)
front axle, dana 50=3.8 pints, dana 60(drw in your case)=5.8 pints
rear axle= 10.5" 6.9 pints, dana 80(drw)8.5 pints
x-fer case=2.0 quarts
danielmcphail34
Aug 17, 2014 05:17 PM
bobwhyte2002
Apr 22, 2012 12:17 PM
Pontiac67
16
Apr 18, 2011 02:43 PM
buckaroo2219
Mar 27, 2011 07:21 PM
amerimutt
1997 - 2003 F150
18
Dec 27, 2006 06:01 PM
