2004 Expy Lights dim when brakes applied
Thanks, Done that. All is clean and tight. Battery had 12.96v (not running)
and 14.29 (running). Just seems a little weird that it would happen only when applying the brakes. I will check and make sure there is no wires grounding out in the area by the brake switch.
I will see what happens to night when I drive home from work.
