Last night while pulling a trailer my dash lights went out, headlights working.
About 50 miles later they came on very dimly. When I turned the headlights off the whole dashboard lit up normally.This morning they are working. Any suggestions as to what is going on. 2014 XLT 55K miles.
Thanks
The battery and charging system check good. The dashboard lights up when the lights are off. The dimmer sw. may be the culprit. If I try to hold it down till courtesy lights come on it won't work, if I just bump it up slowly the dash lights come on.
Thanks for the input.
Hi stvneil,
Let us know if you track down the source of this issue. If you run into any obstacles, you can always swing by your local Ford Dealership so they can diagnose. If you need any help after your appointment, just say the word.
