leaking water problem
Old Mar 15, 2012 | 08:50 PM
wiro351w's Avatar
wiro351w
welll hello there!!!!!!!!
i have a problem. i took my truck to some dunes and it started leaking water so i went home scared that it would heat up on me. never did after driving for an hour. got home checked underneath and couldn't find where it was leaking i just know it was some where behind the main pulley.
put water in it. didnt leak any more till two days later this time it leaked alot more cheaked again and i coulnt find exactly where it was leaking from. drove 15 min home and it was heatin up alot more. i didnt let it get hoter then 3/4.(i would park it then go) im not an expert but if im right pumps leak from a little hole under the pumps neck when they're tired or broken i guess.
the problem i have now is that when i took off the pump 3 screws/bolts broke
the little hole didnt look like it was leaking.
how can i get them out?????
is it easier to replace the timing chain cover???
Old Mar 15, 2012 | 10:58 PM
Encho's Avatar
Encho
The Southernmost Mod
Your water pump is under that main pulley (it's the one with the fan, right?), the seal is probably giving up, so i would advice replacing it (check anyway to see where the leaks is coming from exactly, it could be an old hose coming into the pump). In any case it's an easy job, just don't let too much time pass by without solving that issue or you could mess that engine up.
To extract broken bolts you might need something like this: http://www.fastenal.com/web/products...3162723&ucst=t
(it was just the result of a search, i haven't used this product).
Btw, Welcome to FTE! .
Old Mar 17, 2012 | 03:07 PM
wiro351w's Avatar
wiro351w
thank you.
im going to buy a new water pump and timing cover. maybe all the hose too just soo i know it all new.
1 question i have now is, i been looking at reverse water pumps and the timing cover..
is there any gains in doing this or all the same thing??????????
Old Mar 17, 2012 | 03:15 PM
Encho's Avatar
Encho
I think a reverse water pump is required depending on the model of vehicle you own, and my guess is that the pump will try to pump the water in the opposite direction of your system, I don't think this would help and it will probably make you kill the engine and pump (Usually it goes like this: WP -> engine -> cooling system -> WP). Just find which is the proper replacement for your pump (then again, it might be a reverse, but it would only depend on your engine, using the wrong pump isn't an upgrade). Try our Sponsors up there ^ for the new hoses and WP.
Old Mar 17, 2012 | 04:11 PM
wiro351w's Avatar
wiro351w
were i have looked they have both options thats why i was wondering..
what do u mean sponsors up there??????????
87f-150stepside
Jan 18, 2013 06:48 AM
1L243
24
Sep 29, 2012 09:52 AM
ghostwhite
Dec 21, 2010 07:48 AM
gofast51004
Mar 5, 2009 08:53 AM
Bob_Smith
1978 - 1996 Big Bronco
Sep 22, 2003 12:32 AM
