''water pump''
Old Dec 20, 2010 | 07:40 PM
ghostwhite's Avatar
ghostwhite
''water pump''
well today my truck spang a major leak. It drained a full radiator in less than 10 minutes. So i tackled the task of removing half of the motor to get to the water pump. Once i got the water pump off and remaining gasket removed this is what i found. it is a where a piece of the rim broke off where the water pump seals against the engine. Any suggestions on how i can fix this?
Old Dec 20, 2010 | 09:53 PM
Archion's Avatar
Archion
Veteran: Marine Corps
If I remember correctly, water doesnt flow in the center cavity normally, only when the pump to plate gasket is bad. Water only is supposed to flow between the two ports inside the plate on the waterpump. That notch is to let it drain in case of a leak I believe.
Old Dec 21, 2010 | 06:13 AM
ri_truck_guy's Avatar
ri_truck_guy
Right on the money Matt...
Old Dec 21, 2010 | 07:48 AM
ghostwhite's Avatar
ghostwhite
Thanks for the great info. Matt. I was worried i would have to find a new timing cover or even try to repair the the gap.
