need help identifying engine
Old Apr 27, 2003 | 06:47 PM
Odus Radford's Avatar
Odus Radford
Just bought remanufactured engine. Is supposed to be 69 351w.
Looked up casting number and am confused as to what I have.
Number is: D1AE 6015-DA-14
This means 1971 out of a Galaxie.
Is this a Windor or M block?
Thanks for the help.
Odus
Old Apr 27, 2003 | 09:29 PM
CJJTulsa's Avatar
CJJTulsa
Scroll to the bottom of this:
http://home1.gte.net/res03net/faqs/block.htm
If you have the block in front of you, does it have the timing cover cast into the block, or does it use a separate aluminum/pot metal cover? If it is one piece, it is an M-block. If it uses the separate cover, it is a Windsor. A D1AE casting number almost sounds like an M-block or a Cleveland, but not sure.
Old Apr 28, 2003 | 08:24 PM
Matts72's Avatar
Matts72
That block is a wheezer, they didn't build the M until 74. If its out of a Galaxie I would think it is a Cleveland. Idunno.
Old Apr 28, 2003 | 09:56 PM
ecarter50's Avatar
ecarter50
400 started in 71 and uses same block as 351m.
Old Apr 29, 2003 | 12:19 AM
Brian S's Avatar
Brian S
A remanufactured engine would often mix and match parts from different casting numbers or years as long as they were the same dimensions. 400s used different blocks prior to '75 when the 351M was introduced.
D1AE 6015-DA-14 is a 351 Windsor block. These blocks were't exclusive to the Galaxie. The 3rd letter "A" is a generic Ford code used in many Ford vehicles. A "Z" code means that it was only offered in Mustangs, like parts used in the Boss engines.
hickory1991
22
May 26, 2022 06:21 AM
StockMan
Jan 8, 2013 02:19 PM
1955 Cusso
Feb 10, 2009 05:00 AM
lr
May 27, 2002 08:17 AM
billydsr
Nov 30, 2000 10:28 PM
