2000 Ranger auto trans ?
Old Mar 15, 2012 | 03:18 PM
ReBilld's Avatar
ReBilld
Hey guys! I'm usually over on the OBS diesel forum, but I need some info from some of you Ranger gurus.
I have a 2000 Ranger, 4x4, 3.0, automatic. I think the torque converter is bad. I drive it everyday, but when I get on an incline the rpms stay up and my speed drops to where I can clearly tell it's not pulling like it should. I don't think it's the trans slipping, it seems to shift fine and doesn,t smell hot or anything. The fluid doesn't look or smell burnt. Just serviced the trans and nothing in the pan, so I figured it's the converter. I bought a new converter but then got to thinking if I'm gonna pull the trans I may as well go ahead and rebuild the thing. It's only got 120k on it.
Does this sound like the converter to you guys? Should I go ahead and rebuild the trans you think? If so does anyone know where I can get a detailed rebuild manual for my trans? I'm not sure but I think it is a 4R44E.
Thanks for any advice, suggestions or info anyone has.
Bill
Old Mar 15, 2012 | 06:10 PM
ReBilld's Avatar
ReBilld
Oh yeah, I forgot to mention, No check engine light.
Old Mar 16, 2012 | 09:34 AM
KhanTyranitar's Avatar
KhanTyranitar
It does sound like the torque converter, but why don't you have codes? Shouldn't your truck have a 5R44e?
If you are going to rebuild it anyway, get a shift kit. The stock trans is designed to slip between shifts to make the shifts feel smoother, at the cost of durability, especially when hauling loads or going up hills. A shift kit firms everything up an in the long run makes the trans much tougher.
Old Mar 16, 2012 | 04:07 PM
ReBilld's Avatar
ReBilld
Thanks for the reply. I think the 5R44E is in the 2001-2009 models. How hard is it to rebuild one, and will I need any special tools? I've never rebuilt an auto trans before but with good instructions I'm sure I can. How much do shift kits run for these and where is the best place to get it?
ford197267
May 2, 2012 09:35 AM
bergy 2000
Apr 30, 2011 02:35 AM
Scolesy8
Nov 22, 2010 04:18 PM
ptr34
Apr 24, 2009 06:10 AM
dodgeguy
Dec 3, 2007 05:38 PM
