429 electrical
Old Mar 15, 2012 | 01:53 PM
Austin J.'s Avatar
Austin J.
429 electrical
I have a 1989 Ford F-700 with the 429 4v. It isn't getting power to the coil when the key is on. It has masses of wires and I don't know where to start. There weren't any related fuses on the fuse panel so I am completely lost.
Old Mar 17, 2012 | 08:17 AM
Austin J.'s Avatar
Austin J.
I haven't been able to find anyone in person that knows anything about these trucks with these engines either.
Old Mar 19, 2012 | 08:34 PM
jwtimme's Avatar
jwtimme
I don't know much about the later years, but you could just find a circuit that is hot with the key on and run you a new fire through the firewall to the coil. Make sure it is hot with key on and with the key in the start position.
Old Mar 20, 2012 | 04:54 PM
Austin J.'s Avatar
Austin J.
I just now got it running. I had to replace the ignition switch that is down on the column that connects to the key cylinder with a rod. Now it purrs. Pretty cheap fix relatively-- Only twenty dollars for the part. The only vehicles that part number is supposed to fit, though, is a 77' or 78' LTD.
00t444e
1997 - 2003 F150
Mar 13, 2019 09:33 AM
sailorman1952
62
Dec 18, 2006 04:40 PM
verne56
Mar 24, 2006 07:00 PM
griff777
Dec 20, 2005 06:20 AM
aka rotten
Jul 1, 2005 11:27 PM
