Sponsored by: Auxito
How to program new key?
Old Mar 12, 2019 | 03:51 PM
00t444e's Avatar
00t444e
I replaced the ignition cylinder on a 00 or 01 model f150 and now it won't start and the theft light blinks, is there a way I can program the new key or does the dealer have to do that?
Old Mar 12, 2019 | 04:22 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
If you have some technical prowess, you can get Forscan and an OBD2 adapter and do it yourself. If you'd rather, the dealer is a sure thing.
Old Mar 12, 2019 | 04:30 PM
00t444e's Avatar
00t444e
I do have forscan and the adapter.
Old Mar 13, 2019 | 09:33 AM
steve(ill)'s Avatar
steve(ill)
There is a pickup coil inside the column around the ignition cylinder... It is looking for the matching key... Even tho you have a NEW key in the lock, you can take the old key and hold real close to the lock, ( or remove the coil and tape the old key inside it) if you need to move the vehicle and cant get it started with the NEW key.
banshee_man_96
Nov 22, 2018 07:20 AM
Autobahn1
1997 - 2003 F150
Mar 22, 2016 11:46 PM
Canuck416
Feb 24, 2011 12:19 PM
SGT_Tripplehorn
1997 - 2003 F150
Aug 2, 2009 06:22 PM
maverick1701
21
Mar 30, 2008 02:06 PM
