Sponsored by: Real Truck
Treating rust on the receiver
Old Mar 14, 2012 | 02:09 PM
RickBetterley's Avatar
RickBetterley
It really pisses me off to see surface rust on the receiver of my 2012, and I haven't even towed yet.
Should I just get used to it, treat it with XTEnd or similiar rust converter, or what?
And if I treat it, how do I keep it from rusting again (perhaps spray some oil on the surfaces after repainting)?
I realize that the ball mount is always going to try to remove the protective paint coating, but I'd like to fight off the resulting rust if possible.
Thanks for any suggestions.
Old Mar 14, 2012 | 02:59 PM
dkf's Avatar
dkf
I use a wire brush to hit any rust spots and use a paint that helps prevent rust on it. The inside of the square gets a light coating of waterproof axle bearing grease to help prevent the drop from rusting fast.
Old Mar 14, 2012 | 03:38 PM
galenfz6's Avatar
galenfz6
I wire brush then "OSPHO" (rust converter) let set 48 hrs, paint then coat with hot boiled linseed oil. I also spray the whole under carriage with the linseed oil every yr. I live on a outer banks island and have seen my old truck out last 2 of my buddies trucks in the rust-out race.
Old Mar 14, 2012 | 04:02 PM
mwsF250's Avatar
mwsF250
And of course, there is always the "move somewhere they don't salt the roads" option...
Not very helpful, I know... But I need to remind myself of one of the reasons I put up with all the idiots out here....
Old Mar 14, 2012 | 06:10 PM
Dim Sum's Avatar
Dim Sum
I'd rather have my truck rust into dust every 10 years than live with some of those wackos.
Old Mar 14, 2012 | 07:59 PM
Kajtek1's Avatar
Kajtek1
Are you talking about the receiver, or the ball?
For the painted, but corroded surface rust converter is good and spray can at HD were $1.99. For the ball invest in stainless steel one and that is it.
Old Mar 14, 2012 | 08:41 PM
Quad Racer's Avatar
Quad Racer
I keep fresh paint on all of the ballmount that doesnt make contact. And on the part of each part that makes contact I just spray it with my used oil mix. Any paint will just come right off in time.
Old Mar 14, 2012 | 09:55 PM
RickBetterley
The receiver; thanks.
Old Mar 15, 2012 | 07:31 AM
T diesel's Avatar
T diesel
Fluid Film® | Corrosion Preventative, Lubricant and Rust Inhibitor
LeviD
May 3, 2017 06:03 PM
Phinxter
Paint & Bodywork
Jan 17, 2012 01:21 PM
jacque_strap
1978 - 1996 Big Bronco
Aug 10, 2004 05:17 PM
wolffpax
Paint & Bodywork
Nov 16, 2003 09:00 PM
bkr2
Nov 23, 2002 02:49 PM
