Surface rust
Old Nov 16, 2003 | 04:46 PM
wolffpax's Avatar
wolffpax
Surface rust
The top of my Bronco II has surface rust in the channels of the roof. What can I do to stop it and make it look better? Should I just wire brush it off, primer and paint? Any info would be greatly appreciated.
Old Nov 16, 2003 | 06:27 PM
uk1050's Avatar
uk1050
wire brush may help if the rust is not to bad. the main thing to do is make sure you get all the rust or it will come back and drip rails are the hardest to repair. primer and paint will definetly help after all the rust is gone.
Old Nov 16, 2003 | 06:31 PM
wolffpax's Avatar
wolffpax
Do I need an etching primer for the bare metal? Or is simply wire brushing the rust and primering sufficient? Should I use bondo to smooth it out?
Thanks for the reply uk1050.
Old Nov 16, 2003 | 07:02 PM
Aekisu's Avatar
Aekisu
<cr>
1) Sand to clean metal
2) Treat with rust converter
3) Prime with epoxy primer
4) Do any necessary bodywork
5) Do additional paint prep
6) Paint
Old Nov 16, 2003 | 08:30 PM
uk1050's Avatar
uk1050
there ya go!
Old Nov 16, 2003 | 09:00 PM
wolffpax's Avatar
wolffpax
Thank you very much guys!
