6.9 pushing coolant
Old Mar 14, 2012 | 01:08 PM
mcfarland123's Avatar
mcfarland123
6.9 pushing coolant
anybody have an idea of why 6.9 is pushing coolant out of overflow when going down the road but not at idle?
Old Mar 14, 2012 | 01:23 PM
joshofalltrades's Avatar
joshofalltrades
well how much is it pushing out? does it suck it back in when it cools? its normal for this or any engine to push some coolant over there as it heats up, then suck it back in as it cools.
if your radiator cap is bad, it will push more coolant over there than it should and leave the cooling system with no pressure. the easiest test for this is to squeeze the upper rad hose while the engine is hot. it should contain enough pressure to be hard. if its soft and/or you hear coolant moving to the overflow tank as you squeeze it, you need a new cap.
Old Mar 14, 2012 | 01:32 PM
mcfarland123
it will push out agout 2 gallons on a 40 mile drive. it never sucks it back in. tried new cap & thermostate.
Old Mar 14, 2012 | 01:40 PM
joshofalltrades
possibly a head gasket problem, you should confirm this by buying a "coolant leak indicator" fluid from your local parts store, just pour it in the radiator and drive a bit, then see if it turned the color that shows a problem.
Old Mar 14, 2012 | 01:46 PM
mcfarland123
ok. i will try that. thanks
Old Mar 15, 2012 | 03:48 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Head gasket or cavitation it sounds like. since it doesnt do it under load im leaning towards cavitation, hopefully you get lucky and its the gasket.
Old Mar 15, 2012 | 04:43 PM
38Chevy454's Avatar
38Chevy454
The kits I am familiar with are known as "block checker" or "coolant test" kits. They have a fluid, but you do not put it in the coolant, instead you suck the vapors, off the top of the coolant in the radiator, through the fluid and if you have hydrocarbons in the coolant it changes color.
I have to agree with the others that if you are blowing out 2 gallons of coolant and your cap is good shape, then you are getting pressurization into the coolant form the combustion chamber. Either head gasket or bad cavitation. Hope for head gasket as that can be replaced and use your engine more. If cavitation then unfortunately time for a new engine.
Old Mar 15, 2012 | 08:08 PM
mcfarland123
ok. had test done & was told it was radiator. put new one in. it is better. anybody know the normal operating temp for 6.9? temp wants to jump from 190 to 210 pulling hill. maybe themostate?
kr98664
Jun 22, 2017 11:06 AM
Dlittle40
1983 - 2012 Ranger & B-Series
Feb 4, 2013 09:19 PM
biggercb
1997 - 2003 F150
Nov 19, 2012 10:36 AM
73Galaxie
May 3, 2003 12:42 AM
01' Super Crew
1997 - 2003 F150
Mar 6, 2003 09:26 PM
