Help choosing replacement injectors
Old Mar 12, 2012 | 09:49 PM
ssrider's Avatar
ssrider
My 05's got 182000 kms on it now. So the extended ford warrenty on the injectors is up. I'm trying to decide which injectors to replace them with. Rockauto has a few different options. The motorcraft injectors have part # 5C3E-9F593-DB. They also have a brand called ULTRAPOWER, which is about $70 cheaper for the set. What do you guys recommend?<!-- google_ad_section_end -->
Old Mar 13, 2012 | 07:57 AM
Coskid's Avatar
Coskid
I would stick with the OEM injectors but I am no expert. $70 just seems like a small price to pay fr something you know is quality and will work correctly the first time around and for as long as you will own the truck too most likely.
Old Mar 13, 2012 | 08:27 AM
ssrider's Avatar
ssrider
Ya I agree with you on that, I would prefer to buy the motorcraft ones. I just want to make sure these are the newer style and not the same bad injectors that I have in there now.
Old Mar 14, 2012 | 08:39 AM
Coskid's Avatar
Coskid
I don't think they still make the ones that they had issues with back in 04 and early 05 so you should be good to go there.
Roasted7
Sep 27, 2012 11:18 AM
kubatob7500
Jun 30, 2012 08:36 AM
Mach1
May 29, 2007 08:58 AM
Stroker Dean
24
Nov 27, 2006 06:25 PM
paradiseandpalms
16
Nov 7, 2006 03:53 AM
