Headlights flashing - Help!
Old Mar 12, 2012 | 05:00 PM
Firealmond's Avatar
Firealmond
Trailering
97 Ford F350 4x4 Powerstroke, 99,000 miles. Headlights just started flashing on and off when windshield wipers are on.
Any suggestions?
Old Mar 12, 2012 | 05:04 PM
ReBilld's Avatar
ReBilld
Any suggestions?
Do they do it on high and low beam?
Old Mar 12, 2012 | 05:13 PM
Firealmond's Avatar
Firealmond
Trailering
Stopped flashing when I shifted to low beam but I turned off the wipers immediately after that.
Old Mar 12, 2012 | 05:22 PM
ReBilld's Avatar
ReBilld
Sounds like maybe you have a bad multi-function switch.
Old Mar 12, 2012 | 09:48 PM
f350rebel7788's Avatar
f350rebel7788
Disabled USMC Veteran
I had this problem with my truck a while back. I replaced the headlight switch and it was all better. the old one had a short i think (it had actually gotten hot enough it had melted).
Old Mar 12, 2012 | 09:53 PM
nateairman's Avatar
nateairman
While you are in there put a high beam and low beam relay in that takes the current out of the switch... I will look for a write up. I have done this on other vehicles and it makes a huge difference on brightness (better amperage to the bulbs)
Old Mar 15, 2012 | 01:30 AM
joe_13894's Avatar
joe_13894
I went through 3 headlight switches. After a while the blinking would come back. I changed the bulbs, it still came back. I traced out the wiring looking for a short and found nothing.
I then put in a relay and I haven't had a problem in the 3 years since.
Old Mar 15, 2012 | 08:55 AM
nateairman's Avatar
nateairman
I am not sure how well this will or if it will work if your truck has day time running lights, but here is a link:
https://www.ford-trucks.com/forums/9...as-how-to.html
Old Mar 16, 2012 | 07:12 AM
Jeff396's Avatar
Jeff396
Next time the lights start blinking flash the high beams on and off a few times. If it goes away then I'd think it was the turn signal/high beam stalk. I had a problem with mine where the headlights simply wouldn't come on at times. I replaced the light switch but the problem did not go away. I finally realized that flashing the highs on and off would get then lights to work. When even this didn't work I replaced the stalk and all was good. When I opened up the stalk you could see where it was burned from making a poor connection. I would think that headlights flashing could also be caused by a problem in there. I bought a cheap replacement off ebay but the turn signal canceling thingy broke fairly soon after. Fortunately I kept the old one and was able to swap the plastic part from the old one into the new one and it's been working great ever since. I'd guess it's been over a year now. I think I paid $35 if I remember right.
Jeff
Old Mar 16, 2012 | 07:21 AM
bashby's Avatar
bashby
Here's a good writeup on headlight relays from the 80-86 forum: Whiter Whites, Brighter Brights .: Articles
Old Mar 16, 2012 | 07:25 AM
craftsmangary's Avatar
craftsmangary
Look at the plug on the head light switch real close, you are looking for a burnt wire, or plastic will probably show some sign of heat damage. also look at the terminals on the switch for any discoloring. if you see any of this replace the connector and the switch. I think this has been the problem for every flashing headlight problem I have ever fixed.
Skydivelout
Jan 27, 2018 07:09 PM
AKHunter93
Aug 3, 2015 05:57 PM
BIGskinny
20
Jun 5, 2011 01:57 PM
comertrucks
1997 - 2003 F150
Aug 28, 2006 12:03 AM
duhlry
Aerostar
13
Mar 20, 2005 11:03 PM
