Sponsored by: Auxito
Low beam
Old Aug 27, 2006 | 10:26 AM
comertrucks's Avatar
comertrucks
Low beam
I have a 2001 supercrew 4x4 and my low beam headlights quit. The high beams work fine. What do I look at first? Some one told me if one bulb goes bad they both won't work. Is that true? Thanks Doug
Old Aug 27, 2006 | 10:45 PM
Racerguy's Avatar
Racerguy
If both lights quit at the same time then the problem is probably the multifunction (dimmer/wiper) switch. If one died and then the other you might have burned out bulbs or fuses. Check the fuses first.
Old Aug 28, 2006 | 12:03 AM
comertrucks
Checked the fuses first and they were good. Checked the lamps next and one was burnt out. Put two new bulbs in and now it works fine.
